Заказные клавиатуры Accord по вашему ТЗ
Datasheet ТI DAC5652IPFB — Даташит
СерияDAC5652
МодельDAC5652IPFB
Datasheet Texas Instruments DAC5652IPFB
Двухканальный 10-разрядный цифро-аналоговый преобразователь (ЦАП) с быстродействием 275 MSPS 48-TQFP от -40 до 85
Dual 10 Bit 275 MSPS Digital-to-Analog Converter datasheet
PDF, 675 Кб, Версия: C, Файл опубликован: 29 ноя 2010
  • Passive Terminations for Current Output DACs
    PDF, 244 Кб, Файл опубликован: 10 ноя 2008
    The correct implementation of the high-speed DAC output termination is critical to achieving the best possible performance. The typical application involves choosing the correct network to create the necessary dc bias levels and correct effective impedance load to keep the output voltage within the compliance levels. This ensures that the maximum output signal amplitude and optimum ac performance
  • High Speed Digital-to-Analog Converters Basics (Rev. A)
    PDF, 829 Кб, Версия: A, Файл опубликован: 23 окт 2012
  • Wideband Complementary Current Output DAC Single-Ended Interface
    PDF, 597 Кб, Файл опубликован: 21 июн 2005
    High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op ampdifferential to single-ended stage has often been used. This application note steps through the exact design equations required to achieve gain matching from each output as well as a matched input impedance to each of the DA
Серия: DAC5652 (2)
  • Semiconductors > Data Converters > Digital-to-Analog Converters (DACs) > High Speed DACs (>10MSPS)
На английском языке: Datasheet Texas Instruments DAC5652IPFB
Политика конфиденциальности
