Datasheet Texas Instruments DAC904E — Даташит
СерияDAC904
МодельDAC904E
14-битный цифро-аналоговый преобразователь (ЦАП) со скоростью 165 MSPS 28-TSSOP от -40 до 85
DAC904 14-Bit 165-MSPS Digital-to-Analog Converter datasheet
PDF, 1.0 Мб, Версия: C, Файл опубликован: 29 май 2002
Pin28
Package TypePW
Industry STD TermTSSOP
Package QTY50
МаркировкаDAC904E
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
АрхитектураCurrent Source
DAC Channels1
InterfaceParallel CMOS
Interpolation1x
Package GroupTSSOP
Package Size: mm2:W x L28TSSOP: 62 mm2: 6.4 x 9.7(TSSOP) PKG
Power Consumption(Typ)170 mW
Разрешение14 Bits
SFDR68 дБ
Sample / Update Rate200 MSPS
  • Evaluation Modules & Boards: DAC904EVM
    DAC904 14-Bit 165-MSPS Digital-to-Analog Converter (DAC) Evaluation Module
  • Evaluation Modules & Boards: TSW2200EVM
    TSW2200 Low-Cost Portable Power Supply Evaluation Module
  • High Speed Digital-to-Analog Converters Basics (Rev. A)
    PDF, 829 Кб, Версия: A, Файл опубликован: 23 окт 2012
  • Wideband Complementary Current Output DAC Single-Ended Interface
    PDF, 597 Кб, Файл опубликован: 21 июн 2005
    High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op ampdifferential to single-ended stage has often been used. This application note steps through the exact design equations required to achieve gain matching from each output as well as a matched input impedance to each of the DA
Серия: DAC904 (4)
  • Semiconductors > Data Converters > Digital-to-Analog Converters (DACs) > High Speed DACs (>10MSPS)
На английском языке: Datasheet Texas Instruments DAC904E
