Заказные клавиатуры Accord по вашему ТЗ
Datasheet ТI ADS1286PA — Даташит
СерияADS1286
МодельADS1286PA
Datasheet Texas Instruments ADS1286PA
12-битный аналого-цифровой преобразователь с микровыборкой мощности 8-PDIP от -40 до 85
12-Bit Micro Power Sampling Analog-To-Digital Converter datasheet
PDF, 473 Кб, Файл опубликован: 27 сен 2000
  • Voltage Reference Scaling Techniques Increase Converter and Resolution Accuracy (Rev. A)
    PDF, 67 Кб, Версия: A, Файл опубликован: 8 май 2015
  • Interfacing the ADS7822 to synchronous serial port of the 80x51 Microcontroller
    PDF, 69 Кб, Файл опубликован: 27 сен 2000
    Analog-to-digital converters can be controlled by a normal I/O port or with the synchronous serial port of the 80x51 microcontrollers. The synchronous serial port is more efficient, however, there are some pitfalls to be aware of when configuring the 8-pin A/D converters (ADS1286, ADS7816, ADS7817 and ADS7822) from Burr-Brown. This application bulletin describes how to get around these pitfalls an
  • Coding Schemes Used with Data Converters (Rev. A)
    PDF, 70 Кб, Версия: A, Файл опубликован: 15 май 2015
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
На английском языке: Datasheet Texas Instruments ADS1286PA
Политика конфиденциальности
