Datasheet Analog Devices LTC4364IDE-2#PBF — Даташит
Серия | LTC4364 |
Модель | LTC4364IDE-2#PBF |
Ограничитель перенапряжения с идеальным диодом
Datasheet LTC4364-1, LTC4364-2
PDF, 314 Кб, Язык: анг., Файл закачен: 25 окт 2017, Страниц: 24
Surge Stopper with Ideal Diode
![]() 38 предложений от 17 поставщиков Микросхема Чип управления батареи, Hot Swap Controller 1CH 80V N-Channel Positive High Voltage Automotive 14Pin DFN EP Tube | |||
LTC4364IDE-2#PBF | 802 ₽ | ||
LTC4364IDE-2#PBF Analog Devices | от 1 095 ₽ | ||
LTC4364IDE-2#TRPBF Analog Devices | от 1 200 ₽ | ||
LTC4364IDE-2#PBF Analog Devices | по запросу |
Корпус | 14-Lead DFN (4mm x 3mm w/ EP) |
Количество выводов | 14 |
Код корпуса | 05-08-1708 |
Количество каналов | 1 |
Circuit Breaker Threshold | 50mV |
Power Management Function | Circuit Breaker, Current Limit, Reverse Current Blocking, Reverse Input Protection, Reverse Output Protection, Surge Stopper, UV Lockout |
Total Quiescent Current(typ) | 483µ A |
Vin Range | 4V to 80V |
Серия: LTC4364 (36)
- LTC4364CDE-1#PBF LTC4364CDE-1#TRPBF LTC4364CDE-2#PBF LTC4364CDE-2#TRPBF LTC4364CMS-1#PBF LTC4364CMS-1#TRPBF LTC4364CMS-2#PBF LTC4364CMS-2#TRPBF LTC4364CS-1#PBF LTC4364CS-1#TRPBF LTC4364CS-2#PBF LTC4364CS-2#TRPBF LTC4364HDE-1#PBF LTC4364HDE-1#TRPBF LTC4364HDE-2#PBF LTC4364HDE-2#TRPBF LTC4364HMS-1#PBF LTC4364HMS-1#TRPBF LTC4364HMS-2#PBF LTC4364HMS-2#TRPBF LTC4364HS-1#PBF LTC4364HS-1#TRPBF LTC4364HS-2#PBF LTC4364HS-2#TRPBF LTC4364IDE-1#PBF LTC4364IDE-1#TRPBF LTC4364IDE-2#PBF LTC4364IDE-2#TRPBF LTC4364IMS-1#PBF LTC4364IMS-1#TRPBF LTC4364IMS-2#PBF LTC4364IMS-2#TRPBF LTC4364IS-1#PBF LTC4364IS-1#TRPBF LTC4364IS-2#PBF LTC4364IS-2#TRPBF
- Power Monitor, Control, & Protection > High Voltage Hot Swap Controllers | Surge Stopper, Overvoltage & Overcurrent Protection | PowerPath, Ideal Diodes & Load Switches
LTC4364IDE-2PBF, LTC4364IDE-2 PBF, LTC4364IDE2#PBF, LTC4364IDE 2#PBF
