Datasheet Songle Relay SRS (4000) — Даташит
ПроизводительSongle Relay
СерияSRS (4000)
Сверхминиатюрное реле высокой мощности 1А/3А
Datasheet SRS (4000)
PDF, 3.8 Мб, Файл закачен: 14 июл 2018, Страниц: 2
Subminature High Power Relay 1A/3A
SRS-03VDC-FDSRS-03VDC-FLSRS-03VDC-SDSRS-03VDC-SLSRS-05VDC-FDSRS-05VDC-FLSRS-05VDC-SDSRS-05VDC-SLSRS-06VDC-FDSRS-06VDC-FLSRS-06VDC-SDSRS-06VDC-SLSRS-09VDC-FDSRS-09VDC-FLSRS-09VDC-SDSRS-09VDC-SLSRS-12VDC-FDSRS-12VDC-FLSRS-12VDC-SDSRS-12VDC-SLSRS-24VDC-FDSRS-24VDC-FLSRS-24VDC-SDSRS-24VDC-SL
N123456789101112131415161718192021222324
Размеры, мм15.7×10.6×12.415.7×10.6×12.415.7×10.6×12.415.7×10.6×12.415.7×10.6×12.415.7×10.6×12.415.7×10.6×12.415.7×10.6×12.415.7×10.6×12.415.7×10.6×12.415.7×10.6×12.415.7×10.6×12.415.7×10.6×12.415.7×10.6×12.415.7×10.6×12.415.7×10.6×12.415.7×10.6×12.415.7×10.6×12.415.7×10.6×12.415.7×10.6×12.415.7×10.6×12.415.7×10.6×12.415.7×10.6×12.415.7×10.6×12.4
Parameters / ModelsSRS-03VDC-FD
SRS-03VDC-FD
SRS-03VDC-FL
SRS-03VDC-FL
SRS-03VDC-SD
SRS-03VDC-SD
SRS-03VDC-SL
SRS-03VDC-SL
SRS-05VDC-FD
SRS-05VDC-FD
SRS-05VDC-FL
SRS-05VDC-FL
SRS-05VDC-SD
SRS-05VDC-SD
SRS-05VDC-SL
SRS-05VDC-SL
SRS-06VDC-FD
SRS-06VDC-FD
SRS-06VDC-FL
SRS-06VDC-FL
SRS-06VDC-SD
SRS-06VDC-SD
SRS-06VDC-SL
SRS-06VDC-SL
SRS-09VDC-FD
SRS-09VDC-FD
SRS-09VDC-FL
SRS-09VDC-FL
SRS-09VDC-SD
SRS-09VDC-SD
SRS-09VDC-SL
SRS-09VDC-SL
SRS-12VDC-FD
SRS-12VDC-FD
SRS-12VDC-FL
SRS-12VDC-FL
SRS-12VDC-SD
SRS-12VDC-SD
SRS-12VDC-SL
SRS-12VDC-SL
SRS-24VDC-FD
SRS-24VDC-FD
SRS-24VDC-FL
SRS-24VDC-FL
SRS-24VDC-SD
SRS-24VDC-SD
SRS-24VDC-SL
SRS-24VDC-SL
Номинальное рабочее напряжение, В33335555666699991212121224242424
  • Signal Relay
На английском языке: Datasheet Songle Relay SRS (4000)
