Datasheet Songle Relay SRC (4078) — Даташит
| Производитель | Songle Relay |
| Серия | SRC (4078) |
Реле преобразования двойной группы 1А
Datasheet SRC
PDF, 3.7 Мб, Файл закачен: 14 июл 2018, Страниц: 2
Double Group Conversion Relay 1A
| SRC-05VDC-FH | SRC-05VDC-FL | SRC-05VDC-SH | SRC-05VDC-SL | SRC-06VDC-FH | SRC-06VDC-FL | SRC-06VDC-SH | SRC-06VDC-SL | SRC-09VDC-FH | SRC-09VDC-FL | SRC-09VDC-SH | SRC-09VDC-SL | SRC-12VDC-FH | SRC-12VDC-FL | SRC-12VDC-SH | SRC-12VDC-SL | SRC-18VDC-FH | SRC-18VDC-FL | SRC-18VDC-SH | SRC-18VDC-SL | SRC-24VDC-FH | SRC-24VDC-FL | SRC-24VDC-SH | SRC-24VDC-SL | |
| N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 | 20 | 21 | 22 | 23 | 24 |
| Размеры, мм | 20.2×10.0×12.2 | 20.2×10.0×12.2 | 20.2×10.0×12.2 | 20.2×10.0×12.2 | 20.2×10.0×12.2 | 20.2×10.0×12.2 | 20.2×10.0×12.2 | 20.2×10.0×12.2 | 20.2×10.0×12.2 | 20.2×10.0×12.2 | 20.2×10.0×12.2 | 20.2×10.0×12.2 | 20.2×10.0×12.2 | 20.2×10.0×12.2 | 20.2×10.0×12.2 | 20.2×10.0×12.2 | 20.2×10.0×12.2 | 20.2×10.0×12.2 | 20.2×10.0×12.2 | 20.2×10.0×12.2 | 20.2×10.0×12.2 | 20.2×10.0×12.2 | 20.2×10.0×12.2 | 20.2×10.0×12.2 |
| Parameters / Models | SRC-05VDC-FH![]() | SRC-05VDC-FL![]() | SRC-05VDC-SH![]() | SRC-05VDC-SL![]() | SRC-06VDC-FH![]() | SRC-06VDC-FL![]() | SRC-06VDC-SH![]() | SRC-06VDC-SL![]() | SRC-09VDC-FH![]() | SRC-09VDC-FL![]() | SRC-09VDC-SH![]() | SRC-09VDC-SL![]() | SRC-12VDC-FH![]() | SRC-12VDC-FL![]() | SRC-12VDC-SH![]() | SRC-12VDC-SL![]() | SRC-18VDC-FH![]() | SRC-18VDC-FL![]() | SRC-18VDC-SH![]() | SRC-18VDC-SL![]() | SRC-24VDC-FH![]() | SRC-24VDC-FL![]() | SRC-24VDC-SH![]() | SRC-24VDC-SL![]() |
| Номинальное рабочее напряжение, В | 5 | 5 | 5 | 5 | 6 | 6 | 6 | 6 | 9 | 9 | 9 | 9 | 12 | 12 | 12 | 12 | 18 | 18 | 18 | 18 | 24 | 24 | 24 | 24 |
Серия: SRC (4078) (24)
- SRC-05VDC-FH SRC-05VDC-FL SRC-05VDC-SH SRC-05VDC-SL SRC-06VDC-FH SRC-06VDC-FL SRC-06VDC-SH SRC-06VDC-SL SRC-09VDC-FH SRC-09VDC-FL SRC-09VDC-SH SRC-09VDC-SL SRC-12VDC-FH SRC-12VDC-FL SRC-12VDC-SH SRC-12VDC-SL SRC-18VDC-FH SRC-18VDC-FL SRC-18VDC-SH SRC-18VDC-SL SRC-24VDC-FH SRC-24VDC-FL SRC-24VDC-SH SRC-24VDC-SL
- Signal Relay
