Datasheet ТI ADS8342IPFBT — Даташит
| Серия | ADS8342 |
| Модель | ADS8342IPFBT |
16-разрядный АЦП с параллельным выходом, 250 kSPS, 4 истинно биполярных канала 48-TQFP от -40 до 85
ADS8342: 16-Bit, 250kSPS, 4-Channel, Parallel Output Analog-to-Digital Converter datasheet
PDF, 1.5 Мб, Файл опубликован: 6 фев 2003
- ADS8342 ADC SAR InputsPDF, 223 Кб, Файл опубликован: 6 янв 2005
Successive approximation register analog-to-digital converters (SAR ADCs) present a challenging load to the circuitry that drives the analog inputs. Specifications in data sheets may mislead the user into thinking that analog inputs, for example, are static, when in fact they create a highly dynamic load that requires specially designed buffer circuitry. This article looks at the architecture of - Controlling the ADS8342 with TMS320 Series DSP'sPDF, 109 Кб, Файл опубликован: 22 сен 2003
The ADS8342 16-bit, bipolar input, parallel output analog-to-digital converter has a number of features that allow for an easy interface to many of the TMS320? DSP family of digital signal processors from Texas Instruments. This application note focuses on configuring, sampling, and converting analog data presented to the ADS8342 ADC, with software examples using the TMS320C6711 and C5416 DSPs. Th - Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different - Determining Minimum Acquisition Times for SAR ADCs, part 2PDF, 215 Кб, Файл опубликован: 17 мар 2011
Серия: ADS8342 (3)
- ADS8342IBPFBT ADS8342IPFBT ADS8342IPFBTG4
