Datasheet ТI ADS8345NB — Даташит
| Серия | ADS8345 |
| Модель | ADS8345NB |
16-битный 8-канальный аналого-цифровой преобразователь с дискретизацией последовательного вывода 20-SSOP от -40 до 85
ADS8345: 16-Bit, 8-Channel Serial Output Sampling Analog-to-Digital Converter datasheet
PDF, 1.1 Мб, Версия: C, Файл опубликован: 15 апр 2003
- Interfacing the ADS8345 to TMS320C5416 DSPPDF, 1.5 Мб, Файл опубликован: 5 дек 2002
This application report presents a hardware and software solution to interfacing the ADS8345 16-bit, 8-channel, 100 kHz analog-to-digital converter to the C5000? fixed point 16-bit family of digital signal processors (DSP). While this application report primarily focuses on the 8-channel ADS8345 part, the same solution can be utilized for the 4-channel ADS7841/ADS8341/ADS8343 and 8-channel ADS834 - Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different - Determining Minimum Acquisition Times for SAR ADCs, part 2PDF, 215 Кб, Файл опубликован: 17 мар 2011
Серия: ADS8345 (10)
