Datasheet Texas Instruments DDC101U — Даташит
СерияDDC101
МодельDDC101U
20-битный аналого-цифровой преобразователь 24-SOIC
20-Bit Analog-to-Digital Converter datasheet
PDF, 260 Кб, Файл опубликован: 27 сен 2000
Pin24
Package TypeDW
Package QTY25
МаркировкаDDC101U
Width (мм)7.5
Length (мм)15.4
Thickness (мм)2.35
Max Height (мм)2.65
  • Programming Tricks for Higher Conversion Speeds Utilizing Delta Sigma Converters
    PDF, 105 Кб, Файл опубликован: 27 сен 2000
    Delta-Sigma Analog-to-Digital Converters are well known for their innate ability to resolve an analog input signal to very small LSB voltage ranges. The primarily applications for this type of product is in the Industrial Process Control market such as direct transducer interface for pressure, temperature, flow, weigh scales and force measurement systems.
Серия: DDC101 (2)
  • Semiconductors > Sensing Products > Photodiode Sensing
На английском языке: Datasheet Texas Instruments DDC101U
