Datasheet Texas Instruments ADS1201U — Даташит
СерияADS1201
МодельADS1201U
Дельта-сигма-модулятор с высоким динамическим диапазоном 16-SOIC от -40 до 85
High Dynamic Range Delta-Sigma Modulator datasheet
PDF, 341 Кб, Файл опубликован: 27 сен 2000
22 предложений от 22 поставщиков
Микросхема Преобразователь AD, Analog to Digital Converter High Dynamic Range Delta-Sigma Modulator Single ADC Delta-Sigma 1KSPS 24Bit Serial 16Pin SOIC T/R...
Контест
ADS1201U
1 397 ₽
Элитан
ADS1201U
3 278 ₽
МосЧип
ADS1201U/1K
ADS1201U
Pin16
Package TypeDW
Package QTY40
МаркировкаADS1201U
Width (мм)7.5
Length (мм)10.3
Thickness (мм)2.35
Max Height (мм)2.65
# Input Channels1
Analog Voltage AVDD(Max)5.25 В
Analog Voltage AVDD(Min)4.75 В
АрхитектураDelta-Sigma
Digital Supply(Max)5.25 В
Digital Supply(Min)4.75 В
INL(Max)251.7 +/-LSB
Input Range(Max)5 В
Тип входаDifferential
Integrated FeaturesN/A
InterfaceSerial
Multi-Channel ConfigurationN/A
Package Size: mm2:W x L16SOIC: 106 mm2: 10.3 x 10.3(SOIC) PKG
Power Consumption(Typ)25 mW
Reference ModeExt,Int
Разрешение24 Bits
Sample Rate (max)1kSPS SPS
Sample Rate(Max)0.001 MSPS
  • Evaluation Modules & Boards: AMC1210MB-EVM
    AMC1210 Mother Board
  • Using the ADS1201 Evaluation Board [745k]
    PDF, 741 Кб, Файл опубликован: 27 сен 2000
    This application bulletin provides information on the operation and usage of the ADS1201U evaluation fixture and provides detailed description of the digital filter design implemented into Xilinx XC4010E Field Programmable Gate Array (FPGA).
  • Comparing the ADS1201 to the CS5321 [745k]
    PDF, 212 Кб, Файл опубликован: 27 сен 2000
    The intent of this application bulletin is to provide a simple means of comparing the operation of the ADS1201 delta-sigma modulator to Crystal's CS5321 delta-sigma modulator. It is not the intent of this document to descibe the theory or the operation behind delta-sigma modulators, it is merely to provide the methodology, configuration, and results of tests that were performed using these modulat
  • Digital Filter Types in Delta-Sigma ADCs
    PDF, 219 Кб, Файл опубликован: 27 июн 2017
    This application report discusses digital filters which are a ubiquitous feature in delta-sigma analog todigital converters (ADCs). Digital low-pass filters are essential to the functionality of a delta-sigma ADCwhich relies on oversampling and noise shaping to push quantization noise out of band. There arevariations between the types of digital filters used in delta-sigma ADCs that provide
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS1201 (3)
На английском языке: Datasheet Texas Instruments ADS1201U
