Datasheet Texas Instruments ADS1253E/2K5 — Даташит
СерияADS1253
МодельADS1253E/2K5
24-битный аналого-цифровой преобразователь малой мощности, 20 кГц, 16-SSOP от -40 до 85
24-Bit, 20kHz, Low Power Analog-to-Digital Converter datasheet
PDF, 1.0 Мб, Версия: B, Файл опубликован: 27 сен 2007
Pin1616
Package TypeDBQDBQ
Industry STD TermSSOPSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
МаркировкаADS1253E
Width (мм)3.93.9
Length (мм)4.94.9
Thickness (мм)1.51.5
Pitch (мм).64.64
Max Height (мм)1.751.75
# Input Channels4
Analog Voltage AVDD(Max)5.25 В
Analog Voltage AVDD(Min)4.75 В
АрхитектураDelta-Sigma
Digital Supply(Max)5.25 В
Digital Supply(Min)4.75 В
INL(Max)251.7 +/-LSB
Input Range(Max)5.25 В
Тип входаDifferential
Integrated Features50/60 Hz Rejection
InterfaceSPI
Package GroupSSOP
Package Size: mm2:W x L16SSOP: 19 mm2: 3.9 x 4.9(SSOP) PKG
Power Consumption(Typ)7.5 mW
Reference ModeExt
Разрешение24 Bits
Sample Rate (max)20kSPS SPS
Sample Rate(Max)0.02 MSPS
THD(Typ)-105 дБ
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Interfacing the ADS1251/52 to the MSP430
    PDF, 264 Кб, Файл опубликован: 8 мар 2005
    This application report demonstrates an effective method to interface the ADS1251 and ADS1252 sigma-delta data converters to the MSP430F449 microcontroller. The software for this application report was developed on the HPA449 development system.
  • A Spreadsheet for Calculating the Frequency Response of the ADS1250-54 (Rev. A)
    PDF, 461 Кб, Версия: A, Файл опубликован: 5 сен 2003
    The ADS1250, ADS1251, ADS1252, ADS1253 and ADS1254 family of high-resolution analog-to-digital converters (ADCs) share an advanced delta-sigma (О”ОЈ) topology. This application note reviews the frequency characteristics of these devices and shows how to use a companion Microsoft Excel? spreadsheet (sbaa103a.zip), available for download from the TI web site, to calculate the frequency res
  • Understanding the ADS1251, ADS1253, and ADS1254 Input Circuitry
    PDF, 39 Кб, Файл опубликован: 17 дек 2002
  • Digital Filter Types in Delta-Sigma ADCs
    PDF, 219 Кб, Файл опубликован: 27 июн 2017
    This application report discusses digital filters which are a ubiquitous feature in delta-sigma analog todigital converters (ADCs). Digital low-pass filters are essential to the functionality of a delta-sigma ADCwhich relies on oversampling and noise shaping to push quantization noise out of band. There arevariations between the types of digital filters used in delta-sigma ADCs that provide
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS1253 (3)
На английском языке: Datasheet Texas Instruments ADS1253E/2K5
