Datasheet Texas Instruments ULN2004AN — Даташит
| Серия | ULN2004A |
| Модель | ULN2004AN |
Высоковольтная, сильноточная транзисторная матрица Дарлингтона 16-PDIP от -20 до 70
ULN200x, ULQ200x High-Voltage, High-Current Darlington Transistor Arrays datasheet
PDF, 1.3 Мб, Версия: O, Файл опубликован: 22 янв 2016
Купить ULN2004AN на РадиоЛоцман.Цены — от 4.92 до 79 ₽78 предложений от 35 поставщиков IC PWR RELAY 7NPN 1:1 16DIP. Bipolar (BJT) Transistor Array 7 NPN Darlington 50V 500mA Through Hole 16-DIP. Transistors - Bipolar... | |||
| ULN2004AN(XBLW) | 10 ₽ | ||
| ULN2004ANE4 Rochester Electronics | 19 ₽ | ||
| ULN2004AN Texas Instruments | от 67 ₽ | ||
| ULN2004AN(TOSH) STMicroelectronics | по запросу | ||
| Pin | 16 |
| Package Type | N |
| Industry STD Term | PDIP |
| JEDEC Code | R-PDIP-T |
| Package QTY | 25 |
| Carrier | TUBE |
| Маркировка | ULN2004AN |
| Width (мм) | 6.35 |
| Length (мм) | 19.3 |
| Thickness (мм) | 3.9 |
| Pitch (мм) | 2.54 |
| Max Height (мм) | 5.08 |
| Mechanical Data | Скачать |
| Delay Time(Typ) | 250 нс |
| Drivers Per Package | 7 |
| Input Compatibility | CMOS |
| Iout/ch(Max) | 500 мА |
| Iout_off(Typ) | 50 uA |
| Output Voltage(Max) | 50 В |
| Package Group | PDIP |
| Package Size: mm2:W x L | See datasheet (PDIP) PKG |
| Peak Output Current | 500 мА |
| Rating | Catalog |
| Switching Voltage(Max) | 50 В |
| Vol@Lowest Spec Current(Typ) | 900 мВ |
| Бессвинцовая технология (Pb Free) | Да |
- Improved Thermal Dissipation and Energy Efficiency for Peripheral DrivingPDF, 330 Кб, Файл опубликован: 30 окт 2014
- Wave Solder Exposure of SMT PackagesPDF, 206 Кб, Файл опубликован: 9 сен 2008
It is common practice to attach surface mount components to the underside of a printed circuit board (PCB) by processing the PCB through a wave soldering operation after gluing the components to the PCB. This paper ummarizes results of several tests performed to understand the performance of surface mount components when exposed to the conditions outlined in JESD22A111. - Stepper Motor Driving with Peripheral Drivers (Rev. A)PDF, 172 Кб, Версия: A, Файл опубликован: 2 дек 2016
This application report describes in detail how to interface stepper motors with TI peripheral drivers. Primarily, this report discusses how to connect and drive stepper motors, including the stepper motor driving patterns. Advantages and disadvantages to each stepping pattern are discussed; and logic tables, timing diagrams, and pictorial representations of each driving pattern are provided.
Серия: ULN2004A (9)
- Semiconductors > Power Management > Peripheral Driver and Actuator
