Datasheet Texas Instruments ULN2004AD — Даташит
СерияULN2004A
МодельULN2004AD
Высоковольтная, сильноточная транзисторная матрица Дарлингтона 16-SOIC от -20 до 70
ULN200x, ULQ200x High-Voltage, High-Current Darlington Transistor Arrays datasheet
PDF, 1.3 Мб, Версия: O, Файл опубликован: 22 янв 2016
40 предложений от 24 поставщиков
IC PWR RELAY 7NPN 1:1 16SOIC. Bipolar (BJT) Transistor Array 7 NPN Darlington 50V 500mA Surface Mount 16-SOIC. Transistors - Bipolar...
ULN2004AD16-U
Diodes
33 ₽
ULN2004AD
от 43 ₽
МосЧип
ULN2004ADS
ULN2004ADE4
Pin16
Package TypeD
Package QTY40
МаркировкаULN2004A
Width (мм)3.91
Length (мм)9.9
Thickness (мм)1.58
Max Height (мм)1.75
Delay Time(Typ)250 нс
Drivers Per Package7
Input CompatibilityCMOS
Iout/ch(Max)500 мА
Iout_off(Typ)50 uA
Output Voltage(Max)50 В
Peak Output Current500 мА
Switching Voltage(Max)50 В
Vol@Lowest Spec Current(Typ)900 мВ
  • Improved Thermal Dissipation and Energy Efficiency for Peripheral Driving
    PDF, 330 Кб, Файл опубликован: 30 окт 2014
  • Wave Solder Exposure of SMT Packages
    PDF, 206 Кб, Файл опубликован: 9 сен 2008
    It is common practice to attach surface mount components to the underside of a printed circuit board (PCB) by processing the PCB through a wave soldering operation after gluing the components to the PCB. This paper ummarizes results of several tests performed to understand the performance of surface mount components when exposed to the conditions outlined in JESD22A111.
  • Stepper Motor Driving with Peripheral Drivers (Rev. A)
    PDF, 172 Кб, Версия: A, Файл опубликован: 2 дек 2016
    This application report describes in detail how to interface stepper motors with TI peripheral drivers. Primarily, this report discusses how to connect and drive stepper motors, including the stepper motor driving patterns. Advantages and disadvantages to each stepping pattern are discussed; and logic tables, timing diagrams, and pictorial representations of each driving pattern are provided.
  • Semiconductors > Power Management > Peripheral Driver and Actuator
На английском языке: Datasheet Texas Instruments ULN2004AD
