Datasheet Texas Instruments TLC5921DAP — Даташит
СерияTLC5921
МодельTLC5921DAP
16-канальный светодиодный драйвер 32-HTSSOP от -20 до 85
LED Driver datasheet
PDF, 397 Кб, Файл опубликован: 28 сен 1999
Pin32
Package TypeDAP
Industry STD TermHTSSOP
Package QTY46
МаркировкаTLC5921
Width (мм)6.2
Length (мм)11
Thickness (мм)1.15
Max Height (мм)1.2
Ch to Ch Accuracy(Typ)1 +/- %
Data Transfer Rate(Typ)20 МГц
Рабочий диапазон температурот -20 до 85 C
Package GroupHTSSOP
Package Size: mm2:W x L32HTSSOP: 89 mm2: 8.1 x 11(HTSSOP) PKG
Special FeaturesError Flag,Fault Detection,LED Open Detection,Power Good,Thermal Shutdown
  • LED Driver--Paralleled Outputs Provide High Current Outputs
    PDF, 957 Кб, Файл опубликован: 25 сен 2006
    This application report describes how to use the TLC5922, TLC5923, and TLC5924 to drive high-current LEDs. These ICs are designed to provide 16 individually controllable constant-current sinks. However, the 16 outputs can be connected in parallel to increase the current drive capability. Paralleling the outputs of these ICs allows the TLC5922, TLC5923, and TLC5924 to drive high-power LEDs such as
  • Semiconductors > Power Management > LED Driver > Signage & Large Display LED Driver
На английском языке: Datasheet Texas Instruments TLC5921DAP
