Datasheet Wago 2000-2217 — Даташит
Серия2000
Модель2000-2217
Двухуровневая клеммная колодка TOPJOB S; заземление/сквозь (PE/N); монтаж на рейку; 2-проводная; ширина 3,5 мм; серая
Actuation typeOpen Tool Slot
Цветgray
Country of originCN
Габариты: глубина69.7 mm / 2.744 inch
Designhorizontal
Fine-stranded conductor0.14 … 1.5 mm² / 24 … 16 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.5 mm² / 20 AWG
Fire load0.139 MJ
GTIN4055143274081
Height from upper-edge of DIN-35 rail51.7 mm / 2.035 inch
Marking levelCenter/side marking
Nominal cross section1 mm²
Number of connection points2
Number of connection points (connection type)2
Number of levels2
Potential markingPE/N
Product Group22 (TOPJOB S)
Rated current13.5 A
Rated current (2)16 A
Rated voltage (III / 3)500 В
Solid conductor0.14 … 1.5 mm² / 24 … 16 AWG
Solid conductor, push-in termination0.5 … 1.5 mm² / 20 … 16 AWG
Strip length9 … 11 mm / 0.35 … 0.43 Inch
Total number of connection points4
Total number of potentials2
Type of mountingDIN-35 rail
Вес9.38 г
Ширина3.5 mm / 0.138 inch
20002217, 2000 2217
На английском языке: Datasheet Wago 2000-2217
