Datasheet Wago 2000-2209/099-000 — Даташит
Двухуровневая клеммная колодка TOPJOB S; с внутренним объединением; монтаж на рейку; 4-проводная; ширина 4,2 мм; синяя
DOUBLE-DECK TERMINAL BLOCK; 4-CO | |||
| 2000-2209 Wago | по запросу | ||
| Actuation type | Open Tool Slot |
| Цвет | blue |
| Connectable conductor materials | Copper |
| Connection technology | Push-in CAGE CLAMP® |
| Country of origin | DE |
| Габариты: глубина | 69.7 mm / 2.744 inch |
| Design | horizontal |
| Fine-stranded conductor | 0.14 … 1.5 mm² / 24 … 16 AWG |
| Fine-stranded conductor with ferrule, push-in termination, from | 0.5 mm² / 20 AWG |
| Fire load | 0.219 MJ |
| GTIN | 4050821037606 |
| Height from upper-edge of DIN-35 rail | 51.7 mm / 2.035 inch |
| Marking level | Center/side marking |
| Nominal cross section | 1 mm² |
| Number of levels | 2 |
| Potential marking | N |
| Product Group | 22 (TOPJOB S) |
| Rated current | 13.5 A |
| Rated current (2) | 16 A |
| Rated impulse voltage (III / 3) | 8 kV |
| Rated voltage (III / 3) | 800 В |
| Solid conductor | 0.14 … 1.5 mm² / 24 … 16 AWG |
| Solid conductor, push-in termination | 0.5 … 1.5 mm² / 20 … 16 AWG |
| Strip length | 9 … 11 mm / 0.35 … 0.43 Inch |
| Total number of connection points | 4 |
| Total number of potentials | 1 |
| Type of mounting | DIN-35 rail |
| Type of wiring | Front-entry wiring |
| Вес | 9.82 г |
| Ширина | 4.2 mm / 0.165 inch |
Серия: 2000 (100 из 161)
- 2000-115 2000-1201 2000-1202 2000-1203 2000-1204 2000-1205 2000-1206 2000-1207 2000-1291 2000-1292 2000-1301 2000-1302 2000-1303 2000-1304 2000-1305 2000-1306 2000-1307 2000-1391 2000-1392 2000-1401 2000-1402 2000-1403 2000-1404 2000-1405 2000-1406 2000-1407 2000-1491 2000-1492 2000-2141 2000-2195 2000-2196 2000-2201 2000-2201/099-000 2000-2202 2000-2202/099-000 2000-2203 2000-2203/099-000 2000-2204 2000-2204/099-000 2000-2207 2000-2207/099-000 2000-2208 2000-2208/099-000 2000-2209 2000-2209/099-000 2000-2217 2000-2217/099-000 2000-2218 2000-2218/099-000 2000-2227 2000-2227/099-000 2000-2228 2000-2228/099-000 2000-2231 2000-2231/099-000 2000-2232 2000-2232/099-000 2000-2233 2000-2233/099-000 2000-2234 2000-2234/099-000 2000-2237 2000-2237/099-000 2000-2238 2000-2238/099-000 2000-2239 2000-2239/099-000 2000-2247 2000-2247/099-000 2000-2248 2000-2248/099-000 2000-2257 2000-2257/099-000 2000-2258 2000-2258/099-000 2000-2291 2000-2292 2000-402 2000-402/000-005 2000-402/000-006 2000-402/000-018 2000-403 2000-403/000-005 2000-403/000-006 2000-404 2000-404/000-005 2000-404/000-006 2000-405 2000-405/000-005 2000-405/000-006 2000-405/011-000 2000-406 2000-406/000-005 2000-406/000-006 2000-406/020-000 2000-407 2000-407/000-005 2000-407/000-006 2000-408 2000-408/000-005
20002209/099000, 2000 2209/099 000
