Datasheet Wago 243-744 — Даташит
4-пров.
4-CONDUCTOR FEMALE PLUG, PUSH WI | |||
| 243-744 Wago | по запросу | ||
модул. разъем на печатную плату; для индивидуальных выводов под пайку; Ø 0,8 мм; Шаг контактов 5,75 мм; 4-пол.
| Clamping spring material | Copper alloy |
| Цвет | light green |
| Conductor diameter | 0.5 … 1 mm |
| Connectable conductor materials | Copper |
| Connection technology | PUSH WIRE® |
| Connector connection type | for PCBs |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 10.5 mm / 0.413 inch |
| Drilled hole diameter (tolerance) | 1.2(+ 0.05 ... - 0.05) мм |
| Fire load | 0.048 MJ |
| GTIN | 4044918441988 |
| Height | 10 mm / 0.394 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Mating direction to the PCB | 90 ° |
| Number of Poles | 4 |
| Number of connection types | 1 |
| Number of levels | 1 |
| PCB contact | THT |
| Pin spacing | 5.75 mm (0.226 inch) |
| Rated current | 6 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 250 В |
| Solder pin diameter | 1 мм |
| Solder pin length | 4.5 мм |
| Solid conductor | 0.5 … 1 mm² / 24 … 18 AWG |
| Strip length | 5 … 6 mm / 0.2 … 0.24 Inch |
| Total number of connection points | 16 |
| Total number of potentials | 4 |
| Вес | 3.1 г |
| Ширина | 23 mm / 0.906 inch |
Серия: 243 (37)
- 243-110 243-112 243-113 243-131 243-144 243-204 243-208 243-211 243-212 243-304 243-308 243-504 243-508 243-721 243-722 243-723 243-724 243-725 243-726 243-742 243-742/000-006 243-742/000-012 243-743 243-743/000-012 243-744 243-744/000-006 243-744/000-007 243-744/000-012 243-745 243-745/000-006 243-745/000-012 243-746 243-746/000-006 243-747 243-748 243-804 243-808
- Wire/Splicing Connectors | Pluggable Connection Systems
