Datasheet Wago 284-101 — Даташит
2-проводная проходная клеммная колодка; 10 мм²; боковые маркерные пазы; для DIN-рейки 35 x 15 и 35 x 7,5; CAGE CLAMP
Купить 284-101 на РадиоЛоцман.Цены — от 15 до 3 693 ₽38 предложений от 19 поставщиков Соединители и Адаптеры, Conn Housing RCP 4POS 9.2mm Crimp ST Cable Mount Automotive Box | |||
| 284101-1 TE Connectivity | 89 ₽ | ||
| 284101-1 TE Connectivity | 124 ₽ | ||
| 284-101 WAGO | 280 ₽ | ||
| 284-101 Wago Оф. дистрибьютор | 300 ₽ | ||
| Цвет | gray |
| Connectable conductor materials | Copper |
| Country of origin | DE |
| Габариты: глубина | 52 mm / 2.047 inch |
| Design | horizontal |
| Fine-stranded conductor | 0.2 … 10 mm² / 24 … 8 AWG |
| Fire load | 0.29 MJ |
| GTIN | 4044918323383 |
| Height from upper-edge of DIN-35 rail | 41.5 mm / 1.634 inch |
| Marking level | Side marking |
| Number of levels | 1 |
| Product Group | 1 (Rail Mounted Terminal Blocks) |
| Rated current | 57 A |
| Rated impulse voltage (III / 3) | 8 kV |
| Rated voltage (III / 3) | 800 В |
| Solid conductor | 0.2 … 10 mm² / 24 … 8 AWG |
| Strip length | 12 … 13 mm / 0.47 … 0.51 Inch |
| Total number of connection points | 2 |
| Total number of potentials | 1 |
| Type of mounting | DIN-35 rail |
| Type of wiring | Side-entry wiring |
| Вес | 18.072 г |
| Ширина | 10 mm / 0.394 inch |
Серия: 284 (65)
- 284-101 284-104 284-107 284-301 284-302 284-308 284-309 284-316 284-317 284-318 284-322 284-325 284-326 284-327 284-328 284-329 284-330 284-331 284-332 284-333 284-334 284-335 284-336 284-337 284-338 284-339 284-340 284-341 284-342 284-343 284-344 284-345 284-346 284-357 284-358 284-367 284-368 284-400 284-402 284-405 284-409 284-412 284-413 284-414 284-415 284-422 284-601 284-604 284-607 284-607/999-950 284-621 284-624 284-681 284-682 284-684 284-687 284-687/999-950 284-691 284-901 284-902 284-904 284-907 284-907/999-950 284-992 284-993
