Datasheet Wago 2002-1202 — Даташит
Серия2002
Модель2002-1202
Клеммная колодка TOPJOB S проходная; монтаж на рейку; 2-проводная; ширина 5,2 мм; оранжевый
19 предложений от 8 поставщиков
Bulk Metal?® Foil Technology Conformally Coated Precision Current Sensing Resistors with TCR of 5 ppm/?°C and values down to 5 m?©...
31 ₽
2002-1202
Оф. дистрибьютор
90 ₽
208 ₽
2002-1202
Actuation typeOpen Tool Slot
Цветorange
Country of originDE
Габариты: глубина48.5 mm / 1.909 inch
Designhorizontal
Fine-stranded conductor0.25 … 4 mm² / 22 … 12 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 18 AWG
Fire load0.109 MJ
GTIN4017332999182
Height from upper-edge of DIN-35 rail32.9 mm / 1.295 inch
Marking levelCenter/side marking
Nominal cross section2.5 mm²
Number of levels1
Product Group22 (TOPJOB S)
Rated current (Ex e II)22 A
Rated current (Ex e II) with jumper20 A
Rated voltage EN (Ex e II)550 В
Solid conductor0.25 … 4 mm² / 22 … 12 AWG
Solid conductor, push-in termination0.75 … 4 mm² / 18 … 12 AWG
Strip length10 … 12 mm / 0.39 … 0.47 Inch
Total number of connection points2
Total number of potentials1
Type of mountingDIN-35 rail
Вес5.079 г
Ширина5.2 mm / 0.205 inch
20021202, 2002 1202
На английском языке: Datasheet Wago 2002-1202
