Datasheet Wago 285-159 — Даташит
Трехфазный комплект; с сильноточными клеммами 50 мм²; только для рейки DIN 35 x 15; медь; 50 мм²; POWER CAGE CLAMP
![]() 10 предложений от 4 поставщиков THREE PHASE SET; WITH 50 MM HIGH | |||
285-159 Wago | от 23 661 ₽ | ||
285-159 | от 23 891 ₽ | ||
285-159 Wago | 39 057 ₽ | ||
285-159 Wago | по запросу |
Цвет | gray, blue, green-yellow |
Connectable conductor materials | Copper |
Connection technology | POWER CAGE CLAMP |
Country of origin | DE |
Габариты: глубина | 94 mm / 3.701 inch |
Design | horizontal |
Fine-stranded conductor | 10 … 70 mm² / 8 … 2/0 AWG |
Fire load | 10.658 MJ |
GTIN | 4045454584269 |
Height from upper-edge of DIN-35 rail | 87 mm / 3.425 inch |
Marking level | Side marking |
Number of levels | 1 |
Product Group | 1 (Rail Mounted Terminal Blocks) |
Rated current | 150 A |
Rated impulse voltage (III / 3) | 8 kV |
Rated voltage (III / 3) | 1000 В |
Solid conductor | 10 … 50 mm² / 8 … 1/0 AWG |
Strip length | 30 mm / 1.18 Inch |
Total number of connection points | 10 |
Total number of potentials | 5 |
Type of mounting | DIN-35 rail |
Type of wiring | Side-entry wiring |
Вес | 812.38 г |
Серия: 285 (83)
- 285-1161 285-1163 285-1164 285-1165 285-1167 285-1167/999-950 285-1169 285-1171 285-1175 285-1176 285-1177 285-1178 285-1179 285-1181 285-1184 285-1185 285-1187 285-131 285-132 285-134 285-135 285-136 285-137 285-137/999-950 285-139 285-141 285-144 285-147 285-148 285-150 285-151 285-154 285-157 285-157/999-950 285-159 285-168 285-169 285-170 285-172 285-175 285-181 285-184 285-187 285-188 285-191 285-194 285-195 285-197 285-197/999-950 285-199 285-327 285-337 285-338 285-400 285-401 285-407 285-415 285-416 285-420 285-421 285-427 285-430 285-435 285-440 285-441 285-447 285-448 285-449 285-450 285-495 285-601 285-604 285-607 285-607/999-950 285-634 285-635 285-637 285-637/999-950 285-691 285-935 285-950 285-992 285-995
