Datasheet Wago 285-1184 — Даташит
2-проводная проходная клеммная колодка; 185 мм²; боковые пазы для маркеров; только для рейки DIN 35 x 15; толщина 2,3 мм; медь; POWER CAGE CLAMP
285-1184, 2-пров. проходная клемма, 50 - 185 мм2, синяя | |||
285-1184 Wago | по запросу | ||
285-1184 Wago Оф. дистрибьютор | по запросу |
Цвет | blue |
Connectable conductor materials | Copper |
Connection technology | POWER CAGE CLAMP |
Country of origin | DE |
Габариты: глубина | 133 mm / 5.236 inch |
Design | horizontal |
Fine-stranded conductor | 50 … 185 mm² / 1/0 AWG … 350 kcmil |
Fine-stranded conductor with ferrule with plastic collar | 50 … 150 mm² / 1/0 AWG … 300 kcmil |
Fine-stranded conductor with ferrule without plastic collar | 50 … 185 mm² / 1/0 AWG … 350 kcmil |
Fire load | 0.408 MJ |
GTIN | 4055143067058 |
Height from upper-edge of DIN-35 rail | 116 mm / 4.567 inch |
Marking level | Side marking |
Nominal cross section | 185 mm² |
Number of levels | 1 |
Product Group | 1 (Rail Mounted Terminal Blocks) |
Rated current | 353 A |
Rated impulse voltage (III / 3) | 12 kV |
Rated impulse voltage (III / 3) 2 | 12 kV |
Rated voltage (III / 3) | 1000 В |
Rated voltage (III / 3) 2 | 1500 В |
Solid conductor | 50 … 185 mm² / 1/0 AWG … 350 kcmil |
Stranded conductor | 50 … 185 mm² / 1/0 AWG … 350 kcmil |
Strip length | 45 … 47 mm / 1.77 … 1.85 Inch |
Total number of connection points | 2 |
Total number of potentials | 1 |
Type of mounting | DIN-35 rail |
Type of wiring | Side-entry wiring |
Вес | 535.18 г |
Ширина | 32 mm / 1.26 inch |
Серия: 285 (83)
- 285-1161 285-1163 285-1164 285-1165 285-1167 285-1167/999-950 285-1169 285-1171 285-1175 285-1176 285-1177 285-1178 285-1179 285-1181 285-1184 285-1185 285-1187 285-131 285-132 285-134 285-135 285-136 285-137 285-137/999-950 285-139 285-141 285-144 285-147 285-148 285-150 285-151 285-154 285-157 285-157/999-950 285-159 285-168 285-169 285-170 285-172 285-175 285-181 285-184 285-187 285-188 285-191 285-194 285-195 285-197 285-197/999-950 285-199 285-327 285-337 285-338 285-400 285-401 285-407 285-415 285-416 285-420 285-421 285-427 285-430 285-435 285-440 285-441 285-447 285-448 285-449 285-450 285-495 285-601 285-604 285-607 285-607/999-950 285-634 285-635 285-637 285-637/999-950 285-691 285-935 285-950 285-992 285-995
2851184, 285 1184
