Datasheet Wago 792-801 — Даташит
Клеммная колодка; IT MD 24; Телекоммуникации; 24 В постоянного тока
SP-D 24VDC X2-C | |||
792-801 Wago | 2 897 ₽ | ||
792-801 Wago | по запросу | ||
022-7928-01 | по запросу |
Capacity line/PG | ≤ 5 pF |
Capacity line/line | ≤ 1 nF |
Connections (number) | 5 |
Country of origin | DE |
Габариты: глубина | 91 mm / 3.583 inch |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 14 AWG |
GTIN | 4017332780742 |
Height from upper-edge of DIN-35 rail | 56 mm / 2.205 inch |
Impedance | 1.8 Ω |
Limit frequency line/line | 6 МГц |
Maximum continuous operating voltage | 23 VAC / 33 VDC |
Nominal current | 0.5 A |
Nominal discharge current (8/20 µs) in total | 10 kA |
Nominal discharge current (8/20 µs) per line | 5 kA |
Nominal operating voltage | 24 VDC |
Product Group | 21 (Special Products Electronic) |
Response time line/PG | ≤ 100 ns |
Solid conductor | 0.08 … 2.5 mm² / 28 … 14 AWG |
Standards/specifications | IEC 61643-21 |
Surrounding air (operating) temperature | -40 … 80 °C |
Surrounding air (storage) temperature | -40 … 80 °C |
Type of mounting | DIN-35 rail |
Voltage protection level line/PG (cat. C2 at IN) | ≤ 750 V |
Voltage protection level line/PG (cat. C3 at IN) | ≤ 650 V |
Voltage protection level line/line (cat. C2 at IN) | ≤ 50 V |
Voltage protection level line/line (cat. C3 at IN) | ≤ 45 V |
Вес | 38.7 г |
Ширина | 6 mm / 0.236 inch |
