Datasheet Wago 400-425/425-124 — Даташит
Через клеммную колодку
|  Купить 400-425 на РадиоЛоцман.Цены — от 1 442 до 40 892 ₽ 7 предложений от 7 поставщиков Электронные Дисплеи, TOUCH SCREEN 4-WIRE 3.9" CLEAR | |||
| 400425 | 2 020 ₽ | ||
| Катушка электромагнитной индукции 400425-117 соленоида ASCO 400425-142 | 4 900 ₽ | ||
| 4004-2-5 3M | 40 892 ₽ | ||
| 40-0425-000 | по запросу | ||
| Цвет | blue |
| Connectable conductor materials | Copper |
| Connection technology | Screw-clamp connection/Studs |
| Country of origin | FR |
| Габариты: глубина | 49 mm / 1.929 inch |
| Design | horizontal |
| GTIN | 4017332280303 |
| Height from upper-edge of DIN-35 rail | 46.5 mm / 1.831 inch |
| Marking level | Side marking |
| Number of levels | 1 |
| Product Group | 1 (Rail Mounted Terminal Blocks) |
| Rated current | 125 A |
| Rated impulse voltage (III / 3) | 8 kV |
| Rated voltage (III / 3) | 1000 В |
| Solid conductor | 16 … 35 mm² / 6 … 2 AWG |
| Strip length | 17 … 19 mm / 0.67 … 0.75 Inch |
| Total number of connection points | 2 |
| Total number of potentials | 1 |
| Type of mounting | DIN-35 rail |
| Type of wiring | Side-entry wiring |
| Вес | 48.8 г |
| Ширина | 16 mm / 0.63 inch |
Серия: 400 (62)
- 400-405/405-767 400-405/405-768 400-405/405-769 400-405/405-770 400-405/405-771 400-405/405-772 400-405/405-773 400-405/405-774 400-405/405-775 400-405/405-776 400-405/405-777 400-405/405-778 400-405/405-779 400-406/406-053 400-406/406-054 400-406/406-126 400-406/406-223 400-415/415-124 400-415/415-556 400-416/416-298 400-416/416-299 400-425/425-124 400-425/425-216 400-425/425-556 400-463/463-430 400-463/463-431 400-465/465-111 400-465/465-575 400-473/473-147 400-473/473-316 400-473/473-317 400-473/473-318 400-473/473-319 400-473/473-323 400-473/473-327 400-473/473-328 400-477/477-508 400-477/477-509 400-477/477-510 400-477/477-511 400-490/490-001 400-490/490-002 400-490/490-003 400-490/490-004 400-490/490-005 400-490/490-016 400-490/490-017 400-490/490-018 400-490/490-019 400-499/499-024 400-499/499-176 400-499/499-704 400-499/499-706 400-499/499-715 400-499/499-717 400-499/499-787 400-499/499-788 400-916/916-302 400-916/916-303 400-916/916-304 400-916/916-305 400-916/916-310
400425/425124, 400 425/425 124
