Datasheet Wago 2002-1549 — Даташит
Серия2002
Модель2002-1549
2-проводная несущая клеммная колодка; для DIN-рейки 35 x 15 и 35 x 7,5; 2,5 мм²; Push-in CAGE CLAMP
Actuation typePush-in Operating tool
Цветgray
Country of originDE
Габариты: глубина99.6 mm / 3.921 inch
Designhorizontal
Fine-stranded conductor0.25 … 4 mm² / 22 … 12 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 18 AWG
Fire load0.226 MJ
GTIN4055143072298
Height from upper-edge of DIN-35 rail32.9 mm / 1.295 inch
Marking levelCenter/side marking
Nominal cross section2.5 mm²
Number of levels1
Product Group22 (TOPJOB S)
Rated current16 A
Rated voltage (III / 3)400 В
Solid conductor0.25 … 4 mm² / 22 … 12 AWG
Solid conductor, push-in termination0.75 … 4 mm² / 18 … 12 AWG
Strip length10 … 12 mm / 0.39 … 0.47 Inch
Total number of connection points2
Total number of potentials2
Type of mountingDIN-35 rail
Вес11.329 г
Ширина5.2 mm / 0.205 inch
20021549, 2002 1549
На английском языке: Datasheet Wago 2002-1549
