Datasheet Wago 2001-1203 — Даташит
Проходная клеммная колодка TOPJOB S; монтаж на рейку; 2-проводная; ширина 4,2 мм; красная
![]() 16 предложений от 5 поставщиков 2001-1203, 2-пров. проходная клемма, 0,25 - 1,5 (2,5) мм2, Ex e II, красная | |||
2001-1203 Wago Оф. дистрибьютор | 104 ₽ | ||
2001-1203 Wago | 151 ₽ | ||
2001-1203 Wago | от 315 ₽ | ||
2001-1203 Wago | по запросу |
Actuation type | Open Tool Slot |
Цвет | red |
Connectable conductor materials | Copper |
Country of origin | DE |
Габариты: глубина | 48.5 mm / 1.909 inch |
Design | horizontal |
Fine-stranded conductor | 0.25 … 2.5 mm² / 22 … 14 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 0.75 mm² / 18 AWG |
Fire load | 0.074 MJ |
GTIN | 4045454537364 |
Height from upper-edge of DIN-35 rail | 32.9 mm / 1.295 inch |
Marking level | Center/side marking |
Nominal cross section | 1.5 mm² |
Number of levels | 1 |
Product Group | 22 (TOPJOB S) |
Rated current (Ex e II) | 17 A |
Rated current (Ex e II) with jumper | 16 A |
Rated voltage EN (Ex e II) | 550 В |
Solid conductor | 0.25 … 2.5 mm² / 22 … 14 AWG |
Solid conductor, push-in termination | 0.75 … 2.5 mm² / 18 … 14 AWG |
Strip length | 9 … 11 mm / 0.35 … 0.43 Inch |
Total number of connection points | 2 |
Total number of potentials | 1 |
Type of mounting | DIN-35 rail |
Type of wiring | Front-entry wiring |
Вес | 3.8 г |
Ширина | 4.2 mm / 0.165 inch |
Серия: 2001 (67)
- 2001-115 2001-1201 2001-1202 2001-1203 2001-1204 2001-1205 2001-1206 2001-1207 2001-1208 2001-1211/1000-410 2001-1211/1000-411 2001-1301 2001-1302 2001-1303 2001-1304 2001-1305 2001-1306 2001-1307 2001-1308 2001-1311/1000-410 2001-1311/1000-411 2001-1321/1000-413 2001-1321/1000-434 2001-1401 2001-1402 2001-1403 2001-1404 2001-1405 2001-1406 2001-1407 2001-1408 2001-1411/1000-410 2001-1411/1000-411 2001-1421/1000-413 2001-1421/1000-434 2001-1441 2001-171 2001-402 2001-403 2001-404 2001-405 2001-405/011-000 2001-406 2001-406/020-000 2001-407 2001-408 2001-409 2001-410 2001-433 2001-434 2001-435 2001-436 2001-437 2001-438 2001-439 2001-440 2001-511 2001-549 2001-552 2001-553 2001-554 2001-555 2001-556 2001-557 2001-558 2001-559 2001-560
20011203, 2001 1203
