Datasheet Wago 2004-1211/1000-401 — Даташит
2-проводная диодная клеммная колодка; с диодом 1N5408
COMPONENT TERMINAL BLOCK; 2-COND | |||
| 2004-1211/1000-401 Wago | по запросу | ||
| Actuation type | Open Tool Slot |
| Цвет | gray |
| Connectable conductor materials | Copper |
| Connection technology | Push-in CAGE CLAMP® |
| Country of origin | DE |
| Габариты: глубина | 52.3 mm / 2.059 inch |
| Design | horizontal |
| Fine-stranded conductor | 0.5 … 6 mm² / 20 … 10 AWG |
| Fine-stranded conductor with ferrule, push-in termination, from | 1.5 mm² / 18 AWG |
| Fire load | 0.142 MJ |
| GTIN | 4050821230953 |
| Height from upper-edge of DIN-35 rail | 32.9 mm / 1.295 inch |
| Marking level | Center/side marking |
| Nominal cross section | 4 mm² |
| Nominal voltage | 250 В |
| Number of levels | 1 |
| Product Group | 22 (TOPJOB S) |
| Reverse voltage | 1000 В |
| Solid conductor | 0.5 … 6 mm² / 20 … 10 AWG |
| Solid conductor, push-in termination | 1.5 … 6 mm² / 14 … 10 AWG |
| Strip length | 11 … 13 mm / 0.43 … 0.51 Inch |
| Total number of connection points | 2 |
| Total number of potentials | 1 |
| Type of mounting | DIN-35 rail |
| Type of wiring | Front-entry wiring |
| Вес | 8.296 г |
| Ширина | 6.2 mm / 0.244 inch |
Серия: 2004 (74)
- 2004-115 2004-1201 2004-1202 2004-1203 2004-1204 2004-1205 2004-1206 2004-1207 2004-1211/1000-400 2004-1211/1000-401 2004-1291 2004-1292 2004-1293 2004-1294 2004-1301 2004-1302 2004-1303 2004-1304 2004-1305 2004-1306 2004-1307 2004-1311/1000-400 2004-1311/1000-401 2004-1391 2004-1392 2004-1393 2004-1394 2004-1401 2004-1402 2004-1403 2004-1404 2004-1405 2004-1406 2004-1407 2004-1408 2004-1411/1000-400 2004-1411/1000-401 2004-1491 2004-1492 2004-1493 2004-1494 2004-171 2004-172 2004-402 2004-403 2004-404 2004-405 2004-405/011-000 2004-406 2004-406/020-000 2004-407 2004-408 2004-409 2004-410 2004-433 2004-434 2004-435 2004-436 2004-437 2004-438 2004-439 2004-440 2004-511 2004-541 2004-549 2004-552 2004-553 2004-554 2004-555 2004-911 2004-911/1000-541 2004-911/1000-542 2004-911/1000-836 2004-911/1000-867
20041211/1000401, 2004 1211/1000 401
