Datasheet Wago 2002-4101 — Даташит
Четырехуровневая клеммная колодка TOPJOB S; проходная/проходная/проходная (L3/L2/L1); монтаж на рейку; 2-проводная; ширина 5,2 мм; серая
 Купить 2002-4101 на РадиоЛоцман.Цены — от 271 до 2 613 ₽8 предложений от 8 поставщиков Bulk Metal?® Foil Technology Conformally Coated Precision Current Sensing Resistors with TCR of 5 ppm/?°C and values down to 5 m?©...  | |||
| 2002-4101 Wago  | 271 ₽ | ||
| 20-024-101 | 2 069 ₽ | ||
| 20-024-101 Aries  | 2 613 ₽ | ||
| 20-024-101 | по запросу | ||
| Actuation type | Open Tool Slot |
| Цвет | gray |
| Connectable conductor materials | Copper |
| Connection technology | Push-in CAGE CLAMP® |
| Country of origin | CN |
| Габариты: глубина | 103.5 mm / 4.075 inch |
| Fine-stranded conductor | 0.25 … 4 mm² / 22 … 12 AWG |
| Fine-stranded conductor with ferrule, push-in termination, from | 0.75 mm² / 18 AWG |
| Fire load | 0.397 MJ |
| GTIN | 4050821579397 |
| Height from upper-edge of DIN-35 rail | 83.9 mm / 3.303 inch |
| Nominal cross section | 2.5 mm² |
| Number of connection points | 2 |
| Number of connection points (connection type) | 2 |
| Number of levels | 4 |
| Potential marking | L1 - L2 - L3 |
| Product Group | 22 (TOPJOB S) |
| Rated current | 20 A |
| Rated current (2) | 25 A |
| Rated impulse voltage (III / 3) | 8 kV |
| Rated voltage (III / 3) | 800 В |
| Solid conductor | 0.25 … 4 mm² / 22 … 12 AWG |
| Solid conductor, push-in termination | 0.75 … 4 mm² / 18 … 12 AWG |
| Strip length | 10 … 12 mm / 0.39 … 0.47 Inch |
| Total number of connection points | 6 |
| Total number of potentials | 3 |
| Type of mounting | DIN-35 rail |
| Type of wiring | Front-entry wiring |
| Вес | 20.309 г |
| Ширина | 5.2 mm / 0.205 inch |
Серия: 2002 (100 из 422)
- 2002-3212/1000-674 2002-3217 2002-3218 2002-3221/1000-413 2002-3221/1000-434 2002-3227 2002-3228 2002-3231 2002-3233 2002-3234 2002-3237 2002-3238 2002-3239 2002-3247 2002-3248 2002-3257 2002-3258 2002-3291 2002-3292 2002-400 2002-401 2002-402 2002-402/000-005 2002-402/000-006 2002-403 2002-403/000-005 2002-403/000-006 2002-404 2002-404/000-005 2002-404/000-006 2002-405 2002-405/000-005 2002-405/000-006 2002-405/011-000 2002-406 2002-406/000-005 2002-406/000-006 2002-406/020-000 2002-407 2002-407/000-005 2002-407/000-006 2002-408 2002-408/000-005 2002-408/000-006 2002-409 2002-409/000-005 2002-409/000-006 2002-410 2002-410/000-005 2002-410/000-006 2002-4101 2002-4111 2002-4127 2002-4131 2002-4141 2002-4157 2002-4191 2002-4192 2002-423 2002-423/000-005 2002-423/000-006 2002-433 2002-434 2002-435 2002-436 2002-437 2002-438 2002-439 2002-440 2002-472 2002-473 2002-473/011-000 2002-474 2002-475 2002-475/011-000 2002-476 2002-477 2002-477/011-000 2002-478 2002-479 2002-479/011-000 2002-480 2002-481 2002-481/011-000 2002-482 2002-492 2002-492/000-012 2002-493 2002-511 2002-541 2002-549 2002-552 2002-553 2002-554 2002-555 2002-556 2002-557 2002-558 2002-559 2002-560
20024101, 2002 4101
