Datasheet Wago 2002-2417 — Даташит
Серия2002
Модель2002-2417
Двухуровневая клеммная колодка TOPJOB S; заземление/сквозь (PE/N); монтаж на рейку; 4-проводная; ширина 5,2 мм; серая
Actuation typeOpen Tool Slot
Цветgray
Country of originCN
Габариты: глубина105.1 mm / 4.138 inch
Designhorizontal
Fine-stranded conductor0.25 … 4 mm² / 22 … 12 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 18 AWG
Fire load0.275 MJ
GTIN4050821144847
Height from upper-edge of DIN-35 rail52.1 mm / 2.051 inch
Marking levelCenter/side marking
Nominal cross section2.5 mm²
Number of connection points4
Number of connection points (connection type)4
Number of levels2
Potential markingPE/N
Product Group22 (TOPJOB S)
Rated current24 A
Rated current (2)28 A
Rated voltage (III / 3)800 В
Solid conductor0.25 … 4 mm² / 22 … 12 AWG
Solid conductor, push-in termination0.75 … 4 mm² / 18 … 12 AWG
Strip length10 … 12 mm / 0.39 … 0.47 Inch
Total number of connection points8
Total number of potentials2
Type of mountingDIN-35 rail
Вес18.557 г
Ширина5.2 mm / 0.205 inch
20022417, 2002 2417
На английском языке: Datasheet Wago 2002-2417
