Datasheet Wago 2002-2434 — Даташит
Двухуровневая клеммная колодка TOPJOB S; проходная/проходная (N/N); с держателем маркера; монтаж на рейку; 4-проводная; ширина 5,2 мм; серая
Купить 2002-2434 на РадиоЛоцман.Цены — от 1 190 до 1 988 ₽14 предложений от 4 поставщиков Клеммные Колодки на DIN-рейку | |||
| 2002-2434 | от 1 190 ₽ | ||
| 2002-2434 Wago | от 1 389 ₽ | ||
| 2002-2434 Wago | 1 988 ₽ | ||
| 2002-2434 Wago | по запросу | ||
| Actuation type | Open Tool Slot |
| Цвет | blue |
| Connectable conductor materials | Copper |
| Connection technology | Push-in CAGE CLAMP® |
| Country of origin | CN |
| Габариты: глубина | 105.1 mm / 4.138 inch |
| Design | horizontal |
| Fine-stranded conductor | 0.25 … 4 mm² / 22 … 12 AWG |
| Fine-stranded conductor with ferrule, push-in termination, from | 0.75 mm² / 18 AWG |
| Fire load | 0.308 MJ |
| GTIN | 4050821144731 |
| Height from upper-edge of DIN-35 rail | 62.7 mm / 2.469 inch |
| Marking level | Center/side marking |
| Nominal cross section | 2.5 mm² |
| Number of connection points | 4 |
| Number of connection points (connection type) | 4 |
| Number of levels | 2 |
| Potential marking | N/N |
| Product Group | 22 (TOPJOB S) |
| Rated current | 24 A |
| Rated current (2) | 28 A |
| Rated impulse voltage (III / 3) | 8 kV |
| Rated voltage (III / 3) | 800 В |
| Solid conductor | 0.25 … 4 mm² / 22 … 12 AWG |
| Solid conductor, push-in termination | 0.75 … 4 mm² / 18 … 12 AWG |
| Strip length | 10 … 12 mm / 0.39 … 0.47 Inch |
| Total number of connection points | 8 |
| Total number of potentials | 2 |
| Type of mounting | DIN-35 rail |
| Type of wiring | Front-entry wiring |
| Вес | 16.209 г |
| Ширина | 5.2 mm / 0.205 inch |
Серия: 2002 (100 из 422)
- 2002-2217 2002-2217/099-000 2002-2218 2002-2218/099-000 2002-2221/1000-413 2002-2221/1000-434 2002-2227 2002-2227/099-000 2002-2228 2002-2228/099-000 2002-2231 2002-2231/099-000 2002-2232 2002-2232/099-000 2002-2233 2002-2233/099-000 2002-2234 2002-2234/099-000 2002-2237 2002-2237/099-000 2002-2238 2002-2238/099-000 2002-2239 2002-2239/099-000 2002-2247 2002-2247/099-000 2002-2248 2002-2248/099-000 2002-2257 2002-2257/099-000 2002-2258 2002-2258/099-000 2002-2291 2002-2292 2002-2295 2002-2296 2002-2401 2002-2402 2002-2403 2002-2404 2002-2407 2002-2408 2002-2409 2002-2417 2002-2418 2002-2427 2002-2428 2002-2431 2002-2432 2002-2433 2002-2434 2002-2437 2002-2438 2002-2439 2002-2447 2002-2448 2002-2457 2002-2458 2002-2491 2002-2492 2002-2601 2002-2602 2002-2603 2002-2604 2002-2607 2002-2608 2002-2609 2002-2611 2002-2611/1000-541 2002-2611/1000-542 2002-2611/1000-836 2002-2611/1000-867 2002-2612 2002-2647 2002-2657 2002-2661 2002-2662 2002-2667 2002-2671 2002-2672 2002-2678 2002-2691 2002-2692 2002-2701 2002-2702 2002-2703 2002-2704 2002-2707 2002-2708 2002-2709 2002-2717 2002-2727 2002-2791 2002-2792 2002-2941 2002-2951 2002-2952 2002-2954 2002-2958 2002-2959
20022434, 2002 2434
