Datasheet Wago 2004-1211/1000-400 — Даташит
Серия2004
Модель2004-1211/1000-400
2-проводная диодная клеммная колодка; с диодом 1N5408
2004-1211/1000-400
Actuation typeOpen Tool Slot
Цветgray
Country of originDE
Габариты: глубина52.3 mm / 2.059 inch
Designhorizontal
Fine-stranded conductor0.5 … 6 mm² / 20 … 10 AWG
Fine-stranded conductor with ferrule, push-in termination, from1.5 mm² / 18 AWG
Fire load0.142 MJ
GTIN4050821230946
Height from upper-edge of DIN-35 rail32.9 mm / 1.295 inch
Marking levelCenter/side marking
Nominal cross section4 mm²
Nominal voltage250 В
Number of levels1
Product Group22 (TOPJOB S)
Reverse voltage1000 В
Solid conductor0.5 … 6 mm² / 20 … 10 AWG
Solid conductor, push-in termination1.5 … 6 mm² / 14 … 10 AWG
Strip length11 … 13 mm / 0.43 … 0.51 Inch
Total number of connection points2
Total number of potentials1
Type of mountingDIN-35 rail
Вес8.296 г
Ширина6.2 mm / 0.244 inch
20041211/1000400, 2004 1211/1000 400
На английском языке: Datasheet Wago 2004-1211/1000-400
