Datasheet Wago 2003-6649 — Даташит
Серия2003
Модель2003-6649
Клеммная колодка многоуровневая для установки; N/L
Actuation typeOpen Tool Slot
Цветgray
Country of originCN
Габариты: глубина110 mm / 4.331 inch
Designangled
Fine-stranded conductor0.25 … 4 mm² / 22 … 12 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 18 AWG
Fire load0.307 MJ
GTIN4050821322078
Height from upper-edge of DIN-35 rail44.3 mm / 1.744 inch
Marking levelCenter/side marking
Nominal cross section2.5 mm²
Number of levels3
Potential markingN/L
Product Group22 (TOPJOB S)
Rated current25 A
Rated voltage (III / 3)400 В
Solid conductor0.25 … 4 mm² / 22 … 12 AWG
Solid conductor, push-in termination0.75 … 4 mm² / 18 … 12 AWG
Strip length10 … 12 mm / 0.39 … 0.47 Inch
Total number of connection points4
Total number of potentials3
Type of mountingDIN-35 rail
Вес17.232 г
Ширина5.2 mm / 0.205 inch
20036649, 2003 6649
На английском языке: Datasheet Wago 2003-6649
