Datasheet Wago 862-8525 — Даташит
4-проводная клеммная колодка для монтажа на шасси; 1 защелкивающаяся ножка в поз.
4-CONDUCTOR CHASSIS-MOUNT TERMIN | |||
| 862-8525 Wago | по запросу | ||
2+4; L3-N-PE-L1-L2; с заземляющим контактом; 5-полюсная
| Actuation type | Operating tool Push-button |
| Цвет | black |
| Connectable conductor materials | Copper |
| Connection technology | Push-in CAGE CLAMP® |
| Country of origin | DE |
| Габариты: глубина | 35 mm / 1.378 inch |
| Fine-stranded conductor | 0.5 … 4 mm² / 20 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.5 … 2.5 mm² / 20 … 12 AWG |
| Fine-stranded conductor with ferrule, push-in termination, from | 0.75 mm² / 18 AWG |
| Fire load | 0.643 MJ |
| GTIN | 4044918510394 |
| Height from the surface | 22.3 mm / 0.878 inch |
| Marking | L3-N-PE-L1-L2 |
| Mounting type | Snap-in mounting foot |
| Number of Poles | 5 |
| Packaging type | bag |
| Pin spacing | 12 mm / 0.472 inch |
| Rated current | 32 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (III / 3) | 500 В |
| Solid conductor | 0.5 … 4 mm² / 20 … 12 AWG |
| Solid conductor, push-in termination | 0.75 … 4 mm² / 18 … 12 AWG |
| Stranded conductor | 0.5 … 4 mm² / 20 … 12 AWG |
| Strip length | 10 … 11 mm / 0.39 … 0.43 Inch |
| Total number of connection points | 20 |
| Total number of potentials | 5 |
| Type of mounting | Chassis-mount |
| Type of wiring | Side-entry wiring |
| Вес | 34.676 г |
| Ширина | 60 mm / 2.362 inch |
Серия: 862 (100 из 133)
- 862-1625/999-950 862-1632 862-1632/999-950 862-1633 862-1633/999-950 862-1634 862-1634/999-950 862-1652 862-1652/999-950 862-1662 862-1662/999-950 862-1693 862-1693/999-950 862-1694 862-1694/999-950 862-2503 862-2504 862-2505 862-2515 862-2525 862-2532 862-2533 862-2534 862-2552 862-2562 862-2593 862-2594 862-2603 862-2604 862-2605 862-2615 862-2625 862-2632 862-2633 862-2634 862-2652 862-2662 862-2693 862-2694 862-482 862-503 862-504 862-505 862-515 862-525 862-532 862-533 862-534 862-552 862-562 862-593 862-594 862-603 862-604 862-605 862-615 862-625 862-632 862-633 862-634 862-652 862-662 862-693 862-694 862-8503 862-8504 862-8505 862-8515 862-8525 862-8533 862-8534 862-8593 862-8594 862-8603 862-8604 862-8605 862-8615 862-8625 862-8633 862-8634 862-8693 862-8694 862-9503 862-9504 862-9505 862-9515 862-9525 862-9533 862-9534 862-9593 862-9594 862-9603 862-9604 862-9605 862-9615 862-9625 862-9633 862-9634 862-9693 862-9694
8628525, 862 8525
