Datasheet Wago 2016-7111 — Даташит
Серия2016
Модель2016-7111
1-проводная клеммная колодка распределения питания; 16 мм²; Push-in CAGE CLAMP
Actuation typePush-in Operating tool
Цветgray
Country of originPL
Габариты: глубина69 mm / 2.717 inch
Designhorizontal
Fine-stranded conductor0.5 … 25 mm² / 20 … 4 AWG
Fine-stranded conductor with ferrule, push-in termination, from6 mm² / 14 AWG
Fire load0.386 MJ
GTIN4044918964562
Height from upper-edge of DIN-35 rail38.1 mm / 1.5 inch
Marking levelCenter/side marking
Nominal cross section16 mm²
Number of levels1
Product Group22 (TOPJOB S)
Rated current65 A
Rated voltage (III / 3)250 В
Solid conductor0.5 … 16 mm² / 20 … 6 AWG
Solid conductor, push-in termination6 … 16 mm² / 14 … 6 AWG
Strip length18 … 20 mm / 0.71 … 0.79 Inch
Total number of connection points1
Total number of potentials1
Type of mountingDIN-35 rail
Вес24.932 г
Ширина12 mm / 0.472 inch
20167111, 2016 7111
На английском языке: Datasheet Wago 2016-7111
