Datasheet Wago 224 — Даташит
Серия224
Datasheet Wago 224
42 предложений от 19 поставщиков
224-101, Клемма для освет. оборудования, (От 1,0 до 2,5) / (0,5 - 2,5) мм.кв.
18 ₽
224-101
от 20 ₽
Элрус
20 ₽
224-1-01
Littelfuse
Parameters / Models224-101
224-101
224-104
224-104
224-112
224-112
224-114
224-114
224-201
224-201
Actuation typePush-inPush-inPush-inPush-inPush-in
Цветgrayblackwhiteblackgray
Connectable conductor materialsCopperCopperCopperCopperCopper
Connection technologyPUSH WIRE®PUSH WIRE®PUSH WIRE®PUSH WIRE®CAGE CLAMP®
Connection technology 2CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®
Connection type (1)Installation side:Installation side:Installation side:Installation side:
Connection type (2)Lighting side:Lighting side:Lighting side:Lighting side:
Country of originCHCHCHCHCH
Габариты: глубина20.4 mm / 0.803 inch20.4 mm / 0.803 inch20.5 mm / 0.807 inch20.5 mm / 0.807 inch42 mm / 1.654 inch
Fine-stranded conductor0.5 … 2.5 mm² / 20 … 16 AWG
Fine-stranded conductor (2)0.5 … 2.5 mm² / 20 … 16 AWG0.5 … 2.5 mm² / 20 … 16 AWG0.5 … 2.5 mm² / 20 … 16 AWG0.5 … 2.5 mm² / 20 … 16 AWG
Fire load, MJ0.0410.0510.0460.0570.099
GTIN40449185838174044918584050404491858359640449185837874044918818407
Height15.5 mm / 0.61 inch15.5 mm / 0.61 inch15.5 mm / 0.61 inch15.5 mm / 0.61 inch15.5 mm / 0.61 inch
Legend (ratings)(II / 2) ≙ Overvoltage category II / Pollution degree 2(II / 2) ≙ Overvoltage category II / Pollution degree 2(II / 2) ≙ Overvoltage category II / Pollution degree 2(II / 2) ≙ Overvoltage category II / Pollution degree 2(II / 2) ≙ Overvoltage category II / Pollution degree 2
Number of connection points1111
Product Group7 (Push Wire Conn.)
Rated current, A2424242424
Rated impulse voltage (II / 2), kV44444
Rated voltage (II / 2), В400400400400400
Solid conductor1 … 2.5 mm² / 14 … 12 AWG1 … 2.5 mm² / 14 … 12 AWG1 … 2.5 mm² / 14 … 12 AWG1 … 2.5 mm² / 14 … 12 AWG0.5 … 2.5 mm² / 20 … 16 AWG
Solid conductor (2)0.5 … 2.5 mm² / 20 … 16 AWG0.5 … 2.5 mm² / 20 … 16 AWG0.5 … 2.5 mm² / 20 … 16 AWG0.5 … 2.5 mm² / 20 … 16 AWG
Strip length9 … 11 mm / 0.35 … 0.43 Inch9 … 11 mm / 0.35 … 0.43 Inch9 … 11 mm / 0.35 … 0.43 Inch9 … 11 mm / 0.35 … 0.43 Inch9 … 11 mm / 0.35 … 0.43 Inch
Total number of connection points22332
Total number of potentials11111
Type of wiringSide-entry wiringSide-entry wiringSide-entry wiringSide-entry wiringSide-entry wiring
Вес, г2.1282.342.0662.745
Ширина8 mm / 0.315 inch8 mm / 0.315 inch9.5 mm / 0.374 inch9.5 mm / 0.374 inch8 mm / 0.315 inch
  • Wire/Splicing Connectors
На английском языке: Datasheet Wago 224
