Datasheet Wago 2102 — Даташит
Серия2102
Datasheet Wago 2102
23 предложений от 8 поставщиков
Клеммная колодка на DIN рейку, Through, 2 вывод(-ов), 22 AWG, 12 AWG, 2.5 мм², Зажим, 24 А
2102-1201
Оф. дистрибьютор
113 ₽
2102-1201
от 280 ₽
2102-1201
от 450 ₽
Parameters / Models2102-1201
2102-1201
2102-1204
2102-1204
2102-1207
2102-1207
2102-1291
2102-1291
2102-1292
2102-1292
2102-1301
2102-1301
2102-1304
2102-1304
2102-1307
2102-1307
2102-1391
2102-1391
2102-1392
2102-1392
2102-5201
2102-5201
2102-5204
2102-5204
2102-5207
2102-5207
2102-5301
2102-5301
2102-5304
2102-5304
2102-5307
2102-5307
Actuation typeLever and Open Tool SlotLever and Open Tool SlotLever and Open Tool SlotLever and Open Tool SlotLever and Open Tool SlotLever and Open Tool SlotLever and Push-buttonLever and Push-buttonLever and Push-buttonLever and Push-buttonLever and Push-buttonLever and Push-button
Actuation type 2, Push-buttonPush-inPush-inPush-inPush-inPush-inPush-inPush-inPush-inPush-inPush-inPush-inPush-in
Цветgraybluegreen-yellowgrayorangegraybluegreen-yellowgrayorangegraybluegreen-yellowgraybluegreen-yellow
Connectable conductor materialsCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopper
Connection technologyPush-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®
Country of originDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDE
Габариты: глубина61.5 mm / 2.421 inch61.5 mm / 2.421 inch63.8 mm / 2.512 inch61.5 mm / 2.421 inch61.5 mm / 2.421 inch72.2 mm / 2.843 inch72.2 mm / 2.843 inch72.2 mm / 2.843 inch72.2 mm / 2.843 inch72.2 mm / 2.843 inch61.5 mm / 2.421 inch61.5 mm / 2.421 inch63.8 mm / 2.512 inch72.2 mm / 2.843 inch72.2 mm / 2.843 inch72.2 mm / 2.843 inch
Designhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontal
Fine-stranded conductor0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 18 AWG0.75 mm² / 18 AWG0.75 mm² / 18 AWG0.75 mm² / 18 AWG0.75 mm² / 18 AWG0.75 mm² / 18 AWG0.75 mm² / 18 AWG0.75 mm² / 18 AWG0.75 mm² / 18 AWG0.75 mm² / 18 AWG0.75 mm² / 18 AWG0.75 mm² / 18 AWG
Fire load, MJ0.1360.1560.1390.1390.1360.1570.1570.153
GTIN4055143741729405514374174340551437417674055143745345405514374535240551437417984055143741804405514374181140551437453694055143745376405514374184240551437418664055143741903405514374192740551437419894055143742009
Height33 mm / 1.299 inch33 mm / 1.299 inch33 mm / 1.299 inch33 mm / 1.299 inch
Height from upper-edge of DIN-35 rail32.9 mm / 1.295 inch32.9 mm / 1.295 inch32.9 mm / 1.295 inch32.9 mm / 1.295 inch32.9 mm / 1.295 inch32.9 mm / 1.295 inch32.9 mm / 1.295 inch32.9 mm / 1.295 inch32.9 mm / 1.295 inch32.9 mm / 1.295 inch32.9 mm / 1.295 inch32.9 mm / 1.295 inch
Insulating materialPolyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)
Legend (ratings)(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3
Marking levelCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side marking
Nominal cross section2.5 mm²2.5 mm²2.5 mm²2.5 mm²2.5 mm²2.5 mm²2.5 mm²2.5 mm²2.5 mm²2.5 mm²2.5 mm²2.5 mm²
Number of levels111111111111
Packaging typeBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOX
Rated current, A2424242424242424
Rated current (2), A3232303032323030
Rated impulse voltage (III / 3), kV88888888
Rated voltage (III / 3), В800800800800800800800800
Solid conductor0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG
Solid conductor, push-in termination0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG
Strip length10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch
Total number of connection points222333222333
Total number of potentials111111111111
Type of mountingDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 rail
Type of wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiring
Вес, г6.9536.9539.9031.511.578.0568.05611.0061.611.796.9966.9969.9468.1428.14211.092
Ширина5.2 mm / 0.205 inch5.2 mm / 0.205 inch5.2 mm / 0.205 inch0.8 mm / 0.031 inch0.8 mm / 0.031 inch5.2 mm / 0.205 inch5.2 mm / 0.205 inch5.2 mm / 0.205 inch0.8 mm / 0.031 inch0.8 mm / 0.031 inch5.2 mm / 0.205 inch5.2 mm / 0.205 inch5.2 mm / 0.205 inch5.2 mm / 0.205 inch5.2 mm / 0.205 inch5.2 mm / 0.205 inch
На английском языке: Datasheet Wago 2102
