Datasheet Wago 2003 — Даташит
Серия2003
Datasheet Wago 2003
Элитан
1 900 ₽
Parameters / Models2003-499
2003-499
2003-500
2003-500
2003-6640
2003-6640
2003-6641
2003-6641
2003-6642
2003-6642
2003-6643
2003-6643
2003-6644
2003-6644
2003-6645
2003-6645
2003-6646
2003-6646
2003-6649
2003-6649
2003-6650
2003-6650
2003-6651
2003-6651
2003-6660
2003-6660
2003-6661
2003-6661
2003-6692
2003-6692
2003-6693
2003-6693
2003-7300
2003-7300
2003-7640
2003-7640
2003-7641
2003-7641
2003-7642
2003-7642
2003-7645
2003-7645
2003-7646
2003-7646
2003-7649
2003-7649
2003-7650
2003-7650
2003-7651
2003-7651
2003-7659
2003-7659
2003-7692
2003-7692
2003-911
2003-911
2003-911/1000-923
2003-911/1000-923
Actuation type, Operating toolOpen Tool SlotOpen Tool SlotOpen Tool SlotOpen Tool SlotOpen Tool SlotOpen Tool SlotOpen Tool SlotOpen Tool SlotOpen Tool SlotOpen Tool SlotOpen Tool SlotPush-inPush-inPush-inPush-inPush-inPush-inPush-inPush-inPush-inPush-in
Цветgraygraygraygraygraygraygraygraygraygraygraygraygraygrayorangeorangeorangegraygraygraygraygraygraygraygraygrayorangegraygray
Connectable conductor materialsCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopper
Connection technologyCAGE CLAMP®CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®
Country of originDEDECNCNCNCNCNCNCNCNCNCNCNCNDEDEDEDEDEDEDEDEDEDEDEDEDEDEDE
Габариты: глубина110 mm / 4.331 inch110 mm / 4.331 inch110 mm / 4.331 inch110 mm / 4.331 inch110 mm / 4.331 inch110 mm / 4.331 inch110 mm / 4.331 inch110 mm / 4.331 inch110 mm / 4.331 inch110 mm / 4.331 inch110 mm / 4.331 inch110 mm / 4.331 inch110 mm / 4.331 inch110 mm / 4.331 inch96 mm / 3.78 inch96 mm / 3.78 inch96 mm / 3.78 inch96 mm / 3.78 inch96 mm / 3.78 inch96 mm / 3.78 inch96 mm / 3.78 inch96 mm / 3.78 inch96 mm / 3.78 inch96 mm / 3.78 inch
Designangledangledangledangledangledangledangledangledangledangledangledangledangledangledangledangledangledangledangledangledangled
Fine-stranded conductor0.5 … 2.5 mm² / 20 … 16 AWG0.5 … 2.5 mm² / 20 … 16 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 18 AWG0.75 mm² / 18 AWG0.75 mm² / 18 AWG0.75 mm² / 18 AWG0.75 mm² / 18 AWG0.75 mm² / 18 AWG0.75 mm² / 18 AWG0.75 mm² / 18 AWG0.75 mm² / 18 AWG0.75 mm² / 18 AWG0.75 mm² / 18 AWG0.75 mm² / 18 AWG0.75 mm² / 18 AWG0.75 mm² / 18 AWG0.75 mm² / 18 AWG0.75 mm² / 18 AWG0.75 mm² / 18 AWG0.75 mm² / 18 AWG0.75 mm² / 18 AWG0.75 mm² / 18 AWG0.75 mm² / 18 AWG
Fire load, MJ0.0650.0640.3090.3160.3070.3090.3160.3080.3080.3070.3060.3060.3090.3090.1120.1240.0050.2520.2470.240.2450.2450.240.2420.2420.2450.0790.171
GTIN40508213221154050821322139405082132212240508213220304050821322047405082146452540508216542924050821322054405082132206140508213220784050821322085405082132209240551430535014055143665483405082132210840508217934894045454708481404545479269540449189255874044918925594404491892560040449189256174044918925624404545473594440454547359514045454792749404491892564840508212704164050821608134
Height44.3 mm / 1.744 inch44.3 mm / 1.744 inch42.3 mm / 1.665 inch
Height from upper-edge of DIN-35 rail44.3 mm / 1.744 inch54.7 mm / 2.154 inch44.3 mm / 1.744 inch44.3 mm / 1.744 inch54.7 mm / 2.154 inch44.3 mm / 1.744 inch44.3 mm / 1.744 inch44.3 mm / 1.744 inch44.3 mm / 1.744 inch44.3 mm / 1.744 inch44.3 mm / 1.744 inch44.3 mm / 1.744 inch42.3 mm / 1.665 inch42.3 mm / 1.665 inch42.3 mm / 1.665 inch42.3 mm / 1.665 inch42.3 mm / 1.665 inch42.3 mm / 1.665 inch42.3 mm / 1.665 inch42.3 mm / 1.665 inch42.3 mm / 1.665 inch
Insulating materialPolyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)
Legend (ratings)(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3
Marking levelCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter markingCenter marking
Nominal cross section2.5 mm²2.5 mm²2.5 mm²2.5 mm²2.5 mm²2.5 mm²2.5 mm²2.5 mm²2.5 mm²2.5 mm²2.5 mm²2.5 mm²2.5 mm²2.5 mm²2.5 mm²2.5 mm²2.5 mm²2.5 mm²2.5 mm²2.5 mm²2.5 mm²
Number of levels333333331133332332333
Plug width10.4 mm / 0.409 inch10.4 mm / 0.409 inch
Potential markingN/L/PENTi/L/PEL/LP2/P1/PELTi/L/PEL/L/PEN/L/PEN/LLNP1/P2/PEL/N/PENT/LNT/L/PEL/LL/L/PEN/L/PEN/LLNLT/L
Product Group22 (TOPJOB S)22 (TOPJOB S)22 (TOPJOB S)22 (TOPJOB S)22 (TOPJOB S)22 (TOPJOB S)22 (TOPJOB S)22 (TOPJOB S)22 (TOPJOB S)22 (TOPJOB S)22 (TOPJOB S)22 (TOPJOB S)22 (TOPJOB S)22 (TOPJOB S)22 (TOPJOB S)22 (TOPJOB S)22 (TOPJOB S)22 (TOPJOB S)22 (TOPJOB S)22 (TOPJOB S)22 (TOPJOB S)22 (TOPJOB S)22 (TOPJOB S)22 (TOPJOB S)22 (TOPJOB S)22 (TOPJOB S)
Rated current, A16161020241020242425252510103232323232323232326.36.3
Rated current (2), A3232323232
Rated impulse voltage (III / 3), kV66446444466644446446664
Rated impulse voltage (III / 3) 2, kV6666666666666
Rated voltage (III / 3), В500500250250400250250250250400400400250250250250400250250400400400250250250
Rated voltage (III / 3) 2, В400400400400400400400400400400400400400
Ratings notepotential - groundpotential - groundpotential - groundpotential - groundpotential - groundpotential - groundpotential - groundpotential - groundpotential - groundpotential - groundpotential - groundpotential - groundpotential - ground
Ratings note 2potential-potentialpotential-potentialpotential-potentialpotential-potentialpotential-potentialpotential-potentialpotential-potentialpotential-potentialpotential-potentialpotential-potentialpotential-potentialpotential-potentialpotential-potential
Solid conductor0.5 … 2.5 mm² / 20 … 16 AWG0.5 … 2.5 mm² / 20 … 16 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG0.25 … 4 mm² / 22 … 12 AWG
Solid conductor, push-in termination0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG0.75 … 4 mm² / 18 … 12 AWG
Stranded conductor0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG
Strip length9 … 11 mm / 0.35 … 0.43 Inch9 … 11 mm / 0.35 … 0.43 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch10 … 12 mm / 0.39 … 0.47 Inch
Total number of connection points11554555542255354554223
Total number of potentials11333333331133232332112
Type of mountingDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 rail
Type of wiringSide-entry wiringSide-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiring
Вес, г3.3283.01819.94220.44917.23219.94220.44920.05220.05217.23212.68612.68619.94219.9423.364.190.1614.16516.713.60816.31816.31813.6089.7539.75313.9342.4512.0912.79
Ширина5.2 mm / 0.205 inch5.2 mm / 0.205 inch5.2 mm / 0.205 inch5.2 mm / 0.205 inch5.2 mm / 0.205 inch5.2 mm / 0.205 inch5.2 mm / 0.205 inch5.2 mm / 0.205 inch5.2 mm / 0.205 inch5.2 mm / 0.205 inch5.2 mm / 0.205 inch5.2 mm / 0.205 inch0.8 mm / 0.031 inch1 mm / 0.039 inch5.2 mm / 0.205 inch5.2 mm / 0.205 inch5.2 mm / 0.205 inch5.2 mm / 0.205 inch5.2 mm / 0.205 inch5.2 mm / 0.205 inch5.2 mm / 0.205 inch5.2 mm / 0.205 inch5.2 mm / 0.205 inch0.8 mm / 0.031 inch10.4 mm / 0.409 inch10.4 mm / 0.409 inch
На английском языке: Datasheet Wago 2003
