Datasheet Wago 283 — Даташит
Серия283
Datasheet Wago 283
29 предложений от 15 поставщиков
Клеммы и Розетки, KK® 254 Breakaway Header, Vertical, with Polarizing Wall, 10Circuits, 0.38µm Gold (Au) Selective Plating
Оптулс
Отвертка electric WIHA 283101 41229
Wiha
2 365 ₽
283-101
TradeElectronics
Molex
283-101_ROHS
Parameters / Models283-101
283-101
283-104
283-104
283-107
283-107
283-301
283-301
283-302
283-302
283-316
283-316
283-317
283-317
283-318
283-318
283-320
283-320
283-322
283-322
283-325
283-325
283-326
283-326
283-327
283-327
283-328
283-328
283-329
283-329
283-330
283-330
283-331
283-331
283-332
283-332
283-333
283-333
283-334
283-334
283-335
283-335
283-336
283-336
283-337
283-337
283-338
283-338
283-350
283-350
283-351
283-351
283-352
283-352
283-353
283-353
283-354
283-354
283-355
283-355
283-357
283-357
283-367
283-367
283-400
283-400
283-402
283-402
283-404
283-404
283-405
283-405
283-407
283-407
283-409
283-409
283-414
283-414
283-415
283-415
283-422
283-422
283-601
283-601
283-604
283-604
283-607
283-607
283-607/999-950
283-607/999-950
283-671
283-671
283-672
283-672
283-674
283-674
283-677
283-677
283-677/999-950
283-677/999-950
283-691
283-691
283-901
283-901
283-902
283-902
283-904
283-904
283-907
283-907
283-907/999-950
283-907/999-950
283-908
283-908
283-992
283-992
283-998
283-998
Actuation typeOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating tool
Цветgraybluegreen-yellowgrayorangegrayorangelight graylight greenorangegraygrayorangeorangeorangelight graylight graygraygraygrayorangeorangegraylight graygraygrayorangeorangelight graylight graygrayorangeyellowgraygrayyellowgraygraygrayyellowyellow-greengraybluegreen-yellowgreen-yellowgrayorangebluegreen-yellowgreen-yellowlight graygrayorangebluegreen-yellowgreen-yellowwhitelight graylight gray
Connectable conductor materialsCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopper
Connection technologyCAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®
Country of originCNCNDECNCNCNCNCNCNDEDEDECNDEDEDEDEDECNCNCNCNCNCNDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDECNCNDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDE
Габариты: глубина58 mm / 2.283 inch58 mm / 2.283 inch58 mm / 2.283 inch58 mm / 2.283 inch58 mm / 2.283 inch80 mm / 3.15 inch80 mm / 3.15 inch80 mm / 3.15 inch57.6 mm / 2.268 inch68 mm / 2.677 inch94.4 mm / 3.717 inch93.5 mm / 3.681 inch80 mm / 3.15 inch94.4 mm / 3.717 inch93.5 mm / 3.681 inch94.4 mm / 3.717 inch93.5 mm / 3.681 inch68 mm / 2.677 inch58 mm / 2.283 inch80 mm / 3.15 inch80 mm / 3.15 inch80 mm / 3.15 inch80 mm / 3.15 inch80 mm / 3.15 inch104.3 mm / 4.106 inch103.4 mm / 4.071 inch104.3 mm / 4.106 inch103.4 mm / 4.071 inch104.3 mm / 4.106 inch103.4 mm / 4.071 inch94.4 mm / 3.717 inch94.4 mm / 3.717 inch13 mm / 0.512 inch13 mm / 0.512 inch13 mm / 0.512 inch13 mm / 0.512 inch80 mm / 3.15 inch80 mm / 3.15 inch80 mm / 3.15 inch80 mm / 3.15 inch104.5 mm / 4.114 inch104.5 mm / 4.114 inch104.5 mm / 4.114 inch104.5 mm / 4.114 inch104.5 mm / 4.114 inch80 mm / 3.15 inch94.5 mm / 3.72 inch94.5 mm / 3.72 inch94.5 mm / 3.72 inch94.5 mm / 3.72 inch94.5 mm / 3.72 inch94.5 mm / 3.72 inch94.5 mm / 3.72 inch104.5 mm / 4.114 inch
Designhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontal
Fine-stranded conductor0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG
Fire load, MJ0.3740.3780.1710.1630.2270.220.230.1230.0810.1850.1420.1080.1820.1420.1820.1430.1460.0720.0650.0720.0680.1080.1130.2040.1550.2040.1550.2040.1560.0740.0850.0050.0320.1250.0610.1360.1080.0380.0610.0310.4680.4650.4490.4490.6190.6190.6190.4650.5360.5360.5360.5020.5020.5020.5360.619
GTIN40508214131104050821413127404545408453040173322863744017332286381401733228642840173322864354017332199391401733228645940173322864734017332291705401733229171240173322864804017332291729401733229173640173325801064017332580113401733228649740173322865034017332286510401733219589840173321959044017332286527401733219938440173322917674017332291774401733229178140173322917984017332291804401733229181140173323372124017332337229401733228653440449183963254044918255479401733228655840449188534084044918255370404491839858940173322865894044918396349405082141313440508214131414045454084547404545408867540449185436374044918543668404491854369940454540845544045454089139404491830822940449182976154044918297776404491829787540454540845614045454089290404545408457840449182978994044918543712
Height44 mm / 1.732 inch44 mm / 1.732 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch36.9 mm / 1.453 inch42.8 mm / 1.685 inch37.5 mm / 1.476 inch36.5 mm / 1.437 inch35 mm / 1.378 inch37.5 mm / 1.476 inch36.5 mm / 1.437 inch37.5 mm / 1.476 inch36.5 mm / 1.437 inch42.8 mm / 1.685 inch38.3 mm / 1.508 inch27 mm / 1.063 inch27 mm / 1.063 inch27 mm / 1.063 inch35 mm / 1.378 inch35 mm / 1.378 inch37.5 mm / 1.476 inch36.5 mm / 1.437 inch37.5 mm / 1.476 inch36.5 mm / 1.437 inch37.5 mm / 1.476 inch36.5 mm / 1.437 inch28.4 mm / 1.118 inch28.4 mm / 1.118 inch
Height from upper-edge of DIN-35 rail45.5 mm / 1.791 inch45.5 mm / 1.791 inch45.5 mm / 1.791 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch
Insulating materialPolyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)
Legend (ratings)(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3
Marking levelSide markingSide markingSide markingSide markingSide markingSide markingSide markingCenter markingCenter markingCenter markingCenter markingCenter markingSide markingCenter markingCenter markingCenter markingCenter markingCenter markingCenter markingCenter markingCenter marking
Number of levels111111111111111111111
Product Group1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)
Rated current, A76762432767676767676767676
Rated current (Ex e II), A636363
Rated impulse voltage (III / 3), kV888888888888
Rated voltage (III / 3), В800800800800800800800800800800800800
Rated voltage EN (Ex e II), В550550550
Solid conductor0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG
Strip length16 … 17 mm / 0.63 … 0.67 Inch16 … 17 mm / 0.63 … 0.67 Inch16 … 17 mm / 0.63 … 0.67 Inch16 … 17 mm / 0.63 … 0.67 Inch16 … 17 mm / 0.63 … 0.67 Inch16 … 17 mm / 0.63 … 0.67 Inch16 … 17 mm / 0.63 … 0.67 Inch16 … 17 mm / 0.63 … 0.67 Inch16 … 17 mm / 0.63 … 0.67 Inch16 … 17 mm / 0.63 … 0.67 Inch16 … 17 mm / 0.63 … 0.67 Inch16 … 17 mm / 0.63 … 0.67 Inch16 … 17 mm / 0.63 … 0.67 Inch16 … 17 mm / 0.63 … 0.67 Inch16 … 17 mm / 0.63 … 0.67 Inch16 … 17 mm / 0.63 … 0.67 Inch16 … 17 mm / 0.63 … 0.67 Inch16 … 17 mm / 0.63 … 0.67 Inch16 … 17 mm / 0.63 … 0.67 Inch16 … 17 mm / 0.63 … 0.67 Inch16 … 17 mm / 0.63 … 0.67 Inch
Total number of connection points222222233333222222223
Total number of potentials111111111111111111111
Type of mountingDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 rail
Type of wiringSide-entry wiringSide-entry wiringSide-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiring
Вес, г27.21427.18441.6245.75.437.557.337.664.074.9146.084.653.616.024.576.074.74.572.42.182.42.273.5913.786.665.037.255.036.865.092.472.840.1677.831.9522.0629.914.942.046.72831.82231.82242.04242.62445.33145.33145.33157.357.331.36635.58835.66935.66946.554746.5735.66945.331
Ширина12 mm / 0.472 inch12 mm / 0.472 inch12 mm / 0.472 inch4 mm / 0.157 inch4 mm / 0.157 inch4 mm / 0.157 inch4 mm / 0.157 inch4 mm / 0.157 inch4 mm / 0.157 inch2 mm / 0.079 inch2.5 mm / 0.098 inch2 mm / 0.079 inch2 mm / 0.079 inch2.5 mm / 0.098 inch2 mm / 0.079 inch2.5 mm / 0.098 inch2 mm / 0.079 inch2 mm / 0.079 inch1 mm / 0.039 inch1 mm / 0.039 inch1 mm / 0.039 inch1 mm / 0.039 inch2 mm / 0.079 inch2 mm / 0.079 inch2.5 mm / 0.098 inch2 mm / 0.079 inch2.5 mm / 0.098 inch2 mm / 0.079 inch2.5 mm / 0.098 inch2 mm / 0.079 inch1 mm / 0.039 inch1 mm / 0.039 inch12 mm / 0.472 inch11.6 mm / 0.457 inch24 mm / 0.945 inch8 mm / 0.315 inch12 mm / 0.472 inch12 mm / 0.472 inch12 mm / 0.472 inch12 mm / 0.472 inch12 mm / 0.472 inch12 mm / 0.472 inch12 mm / 0.472 inch12 mm / 0.472 inch12 mm / 0.472 inch12 mm / 0.472 inch12 mm / 0.472 inch12 mm / 0.472 inch12 mm / 0.472 inch12 mm / 0.472 inch12 mm / 0.472 inch12 mm / 0.472 inch12 mm / 0.472 inch12 mm / 0.472 inch12 mm / 0.472 inch
  • Rail / Chassis Terminal blocks | Pluggable Connection Systems
На английском языке: Datasheet Wago 283
