Линейка продуктов KEEN SIDE
Datasheet Wago 784 — Даташит
Серия784
Datasheet Wago 784
20 предложений от 6 поставщиков
2-CONDUCTOR THROUGH TERMINAL BLO
Зенер
Россия и страны ТС
784-601
от 880 ₽
DIP8.RU
Россия и страны ТС
784-601
от 1 047 ₽
784-601
от 1 110 ₽
Элитан
1 459 ₽
Parameters / Models784-601
784-601
784-604
784-604
784-607
784-607
784-607/999-950
784-607/999-950
784-623
784-623
784-992
784-992
Actuation typeOperating toolOperating toolOperating toolOperating toolOperating toolOperating tool
Цветgraybluegreen-yellowgreen-yellowgraylight gray
Connectable conductor materialsCopperCopperCopperCopperCopperCopper
Connection technologyCAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®
Country of originDEDEDEDEPLDE
Габариты: глубина82.5 mm / 3.248 inch82.5 mm / 3.248 inch82.5 mm / 3.248 inch82.5 mm / 3.248 inch82.5 mm / 3.248 inch82.5 mm / 3.248 inch
Designangledangledangledangledangledangled
Fine-stranded conductor0.2 … 10 mm² / 24 … 8 AWG0.2 … 10 mm² / 24 … 8 AWG0.2 … 10 mm² / 24 … 8 AWG0.2 … 10 mm² / 24 … 8 AWG0.2 … 10 mm² / 24 … 8 AWG0.2 … 10 mm² / 24 … 8 AWG
Fine-stranded conductor (2)0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG
Fire load, MJ0.3570.3570.339
GTIN404491880597140449188059954045454084752404545409279540454540169994044918806022
Height from upper-edge of DIN-35 rail43.5 mm / 1.713 inch43.5 mm / 1.713 inch43.5 mm / 1.713 inch43.5 mm / 1.713 inch43.5 mm / 1.713 inch43.5 mm / 1.713 inch
Insulating materialPolyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)
Legend (ratings)(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3
Marking levelCenter markingCenter markingCenter markingCenter markingCenter markingCenter marking
Number of levels111111
Product Group17 (TOP JOB installation terminal blocks)17 (TOP JOB installation terminal blocks)
Rated current, A575757
Rated impulse voltage (III / 3), kV886
Rated voltage (III / 3), В10001000400
Rated voltage EN (Ex e II), В750
Solid conductor0.2 … 10 mm² / 24 … 8 AWG0.2 … 10 mm² / 24 … 8 AWG0.2 … 10 mm² / 24 … 8 AWG0.2 … 10 mm² / 24 … 8 AWG0.2 … 10 mm² / 24 … 8 AWG0.2 … 10 mm² / 24 … 8 AWG
Solid conductor (2)0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG
Strip length12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch
Total number of connection points222212
Total number of potentials111111
Type of mountingDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 rail
Type of wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiring
Вес, г23.2223.0533.6633.6632.9222.9
Ширина10 mm / 0.394 inch10 mm / 0.394 inch10 mm / 0.394 inch10 mm / 0.394 inch10 mm / 0.394 inch10 mm / 0.394 inch
На английском языке: Datasheet Wago 784
