Datasheet Wago 811 — Даташит
Серия811
Datasheet Wago 811
23 предложений от 16 поставщиков
Обжимные инструменты CRIMPER INSERT
Элитан
4 016 ₽
81-1310-01-301
Dialight
от 4 525 ₽
TE Connectivity
15 323 ₽
TradeElectronics
Parameters / Models811-310
811-310
811-311
811-311
811-314
811-314
811-316
811-316
811-317
811-317
811-320
811-320
811-321
811-321
811-330
811-330
811-331
811-331
811-410
811-410
811-411
811-411
811-414
811-414
811-420
811-420
811-421
811-421
811-430
811-430
811-431
811-431
811-471
811-471
811-472
811-472
811-473
811-473
811-474
811-474
811-475
811-475
811-476
811-476
811-477
811-477
811-478
811-478
811-479
811-479
811-480
811-480
811-481
811-481
811-482
811-482
811-612
811-612
Actuation typeOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating tool
Цветlight graylight graylight graylight graylight graylight graylight graylight graylight graylight graylight graylight graylight graylight graylight graylight graylight graylight graylight graylight graylight graylight graylight graylight graylight graylight graylight graylight gray
Connectable conductor materialsCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopperCopper
Connection technologyCAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®
Country of originCNCNCNDEDEDEDEDEDEDEDEDEDEDEDECN
Габариты: глубина105 mm / 4.134 inch105 mm / 4.134 inch105 mm / 4.134 inch105 mm / 4.134 inch105 mm / 4.134 inch105 mm / 4.134 inch105 mm / 4.134 inch105 mm / 4.134 inch105 mm / 4.134 inch105 mm / 4.134 inch105 mm / 4.134 inch105 mm / 4.134 inch105 mm / 4.134 inch105 mm / 4.134 inch105 mm / 4.134 inch105 mm / 4.134 inch
Designhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontal
Fine-stranded conductor2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG
GTIN40508214988894050821508090405082150813740508218490014050821499251405082150807640508215081064050821877660405082150811340508215081514050821508205405082150830440508215081754050821508281405082150818240508215082984050821838654405082183854840508218385554050821838562405082183857940508218385864050821838593405082183860940508218386164050821838623405082183863040508218386474050821856528
Height from upper-edge of DIN-35 rail55 mm / 2.165 inch55 mm / 2.165 inch55 mm / 2.165 inch55 mm / 2.165 inch55 mm / 2.165 inch55 mm / 2.165 inch55 mm / 2.165 inch55 mm / 2.165 inch55 mm / 2.165 inch55 mm / 2.165 inch55 mm / 2.165 inch55 mm / 2.165 inch55 mm / 2.165 inch55 mm / 2.165 inch55 mm / 2.165 inch55 mm / 2.165 inch
Insulating materialPolyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)
Legend (ratings)(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3
Number of Poles1111122331112233
Number of levels11111111111111111
Packaging typeBOX
Product Group1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)1 (Rail Mounted Terminal Blocks)
Rated current, A323232323232326363636363636363636363
Rated voltage (III / 3), В10001000100010001000100010001000100010001000
Solid conductor2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG2.5 … 16 mm² / 16 … 6 AWG35 mm² / 2 AWG
Strip length12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch
Total number of connection points2222244662224466
Total number of potentials1111122331112233
Type of mountingDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 rail
Type of wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiring
Voltage type (1)ACACACDCDCACACACACAC
Вес, г1.1111.1111.11163.112001.1111.1112001.1111.1111.1111.1111.1111.1111.1111.1112010102020303040405050509.333
Ширина17.5 mm / 0.689 inch17.5 mm / 0.689 inch17.5 mm / 0.689 inch17 mm / 0.669 inch17 mm / 0.669 inch35 mm / 1.378 inch35 mm / 1.378 inch52.5 mm / 2.067 inch52.5 mm / 2.067 inch17.5 mm / 0.689 inch17.5 mm / 0.689 inch17.5 mm / 0.689 inch35 mm / 1.378 inch35 mm / 1.378 inch52.5 mm / 2.067 inch52.5 mm / 2.067 inch
  • Rail / Chassis Terminal blocks | Pluggable Connection Systems
На английском языке: Datasheet Wago 811
