Datasheet Wago 785 — Даташит
Серия785
Datasheet Wago 785
Бачок для унитаза Connect E785601 выполнен в современном стиле. Серия Connect сочетает творческий дизайн и практичные решения. Идельно подходит для оснащения...
785-601
Оф. дистрибьютор
1 467 ₽
Энтеро
Россия, Белоруссия, Казахстан
Connect E785601
Ideal Standard
13 160 ₽
Hi-Tech Circuit Group
785601TN
Parameters / Models785-601
785-601
785-604
785-604
785-607
785-607
785-623
785-623
Actuation typeOperating toolOperating toolOperating toolOperating tool
Цветgraybluegreen-yellowgray
Connectable conductor materialsCopperCopperCopperCopper
Connection technologyCAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®
Country of originDEDEDEDE
Габариты: глубина114 mm / 4.488 inch114 mm / 4.488 inch114 mm / 4.488 inch116.5 mm / 4.587 inch
Designangledangledangledangled
Fire load, MJ1.1031.103
GTIN4045454400576404545440058340454549026504045454601898
Height from upper-edge of DIN-35 rail44.5 mm / 1.752 inch44.5 mm / 1.752 inch44.5 mm / 1.752 inch44.5 mm / 1.752 inch
Insulating materialPolyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)
Legend (ratings)(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3
Marking levelCenter/side markingCenter/side markingCenter/side markingCenter/side marking
Number of levels1111
Product Group17 (TOP JOB installation terminal blocks)17 (TOP JOB installation terminal blocks)17 (TOP JOB installation terminal blocks)17 (TOP JOB installation terminal blocks)
Rated current, A125125125
Rated impulse voltage (III / 3), kV886
Rated voltage (III / 3), В10001000400
Solid conductor6 … 35 mm² / 8 … 2 AWG6 … 35 mm² / 8 … 2 AWG6 … 35 mm² / 8 … 2 AWG6 … 35 mm² / 8 … 2 AWG
Strip length23 mm / 0.91 Inch23 mm / 0.91 Inch23 mm / 0.91 Inch23 mm / 0.91 Inch
Total number of connection points2221
Total number of potentials1111
Type of mountingDIN-35 railDIN-35 railDIN-35 railDIN-35 rail
Type of wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiring
Вес, г86.61587.195110.15391.47
Ширина16 mm / 0.63 inch16 mm / 0.63 inch16 mm / 0.63 inch16 mm / 0.63 inch
Серия: 785 (4)
На английском языке: Datasheet Wago 785
