Datasheet Wago 2202 — Даташит
| Производитель | Wago |
| Серия | 2202 |
Купить 2202-1201 на РадиоЛоцман.Цены — от 31 до 254 ₽26 предложений от 9 поставщиков Клеммная колодка на DIN рейку, Through, 2 вывод(-ов), 12 AWG, 12 AWG, 2.5 мм², Зажим, 24 А | |||
| 2202-1201 Wago | от 239 ₽ | ||
| 2202-1201 Wago | от 254 ₽ | ||
| 2202-1201 Wago | по запросу | ||
| 2202-1201 Wago Оф. дистрибьютор | по запросу | ||
| Parameters / Models | 2202-1201![]() | 2202-1204![]() | 2202-1207![]() | 2202-1301![]() | 2202-1304![]() | 2202-1307![]() | 2202-1401![]() | 2202-1404![]() | 2202-1407![]() |
| Actuation type | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button |
| Цвет | gray | blue | green-yellow | gray | blue | green-yellow | gray | blue | green-yellow |
| Connectable conductor materials | Copper | Copper | Copper | Copper | Copper | Copper | Copper | Copper | Copper |
| Connection technology | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® |
| Country of origin | DE | DE | DE | DE | DE | DE | DE | DE | DE |
| Габариты: глубина | 48.5 mm / 1.909 inch | 48.5 mm / 1.909 inch | 50.8 mm / 2 inch | 59.2 mm / 2.33 inch | 59.2 mm / 2.33 inch | 59.2 mm / 2.33 inch | 69.9 mm / 2.752 inch | 69.9 mm / 2.752 inch | 69.9 mm / 2.752 inch |
| Design | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal |
| Fine-stranded conductor | 0.25 … 4 mm² / 22 … 12 AWG | 0.25 … 4 mm² / 22 … 12 AWG | 0.25 … 4 mm² / 22 … 12 AWG | 0.25 … 4 mm² / 22 … 12 AWG | 0.25 … 4 mm² / 22 … 12 AWG | 0.25 … 4 mm² / 22 … 12 AWG | 0.25 … 4 mm² / 22 … 12 AWG | 0.25 … 4 mm² / 22 … 12 AWG | 0.25 … 4 mm² / 22 … 12 AWG |
| Fine-stranded conductor with ferrule, push-in termination, from | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG |
| Fire load, MJ | 0.151 | ||||||||
| GTIN | 4055143713542 | 4055143713566 | 4055143713580 | 4055143713795 | 4055143713832 | 4055143713856 | 4055143713870 | 4055143713894 | 4055143713917 |
| Height from upper-edge of DIN-35 rail | 32.9 mm / 1.295 inch | 32.9 mm / 1.295 inch | 32.9 mm / 1.295 inch | 32.9 mm / 1.295 inch | 32.9 mm / 1.295 inch | 32.9 mm / 1.295 inch | 32.9 mm / 1.295 inch | 32.9 mm / 1.295 inch | 32.9 mm / 1.295 inch |
| Insulating material | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) |
| Legend (ratings) | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | |||
| Marking level | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking |
| Nominal cross section | 2.5 mm² | 2.5 mm² | 2.5 mm² | 2.5 mm² | 2.5 mm² | 2.5 mm² | 2.5 mm² | 2.5 mm² | 2.5 mm² |
| Number of levels | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| Packaging type | BOX | BOX | BOX | BOX | BOX | BOX | BOX | BOX | BOX |
| Rated current, A | 24 | 24 | 24 | 24 | 24 | 24 | |||
| Rated current (2), A | 32 | 32 | 32 | 32 | 32 | 32 | |||
| Rated impulse voltage (III / 3), kV | 8 | 8 | 8 | 8 | 8 | 8 | |||
| Rated voltage (III / 3), В | 800 | 800 | 800 | 800 | 800 | 800 | |||
| Solid conductor | 0.25 … 4 mm² / 22 … 12 AWG | 0.25 … 4 mm² / 22 … 12 AWG | 0.25 … 4 mm² / 22 … 12 AWG | 0.25 … 4 mm² / 22 … 12 AWG | 0.25 … 4 mm² / 22 … 12 AWG | 0.25 … 4 mm² / 22 … 12 AWG | 0.25 … 4 mm² / 22 … 12 AWG | 0.25 … 4 mm² / 22 … 12 AWG | 0.25 … 4 mm² / 22 … 12 AWG |
| Solid conductor, push-in termination | 0.75 … 4 mm² / 18 … 12 AWG | 0.75 … 4 mm² / 18 … 12 AWG | 0.75 … 4 mm² / 18 … 12 AWG | 0.75 … 4 mm² / 18 … 12 AWG | 0.75 … 4 mm² / 18 … 12 AWG | 0.75 … 4 mm² / 18 … 12 AWG | 0.75 … 4 mm² / 18 … 12 AWG | 0.75 … 4 mm² / 18 … 12 AWG | 0.75 … 4 mm² / 18 … 12 AWG |
| Strip length | 10 … 12 mm / 0.39 … 0.47 Inch | 10 … 12 mm / 0.39 … 0.47 Inch | 10 … 12 mm / 0.39 … 0.47 Inch | 10 … 12 mm / 0.39 … 0.47 Inch | 10 … 12 mm / 0.39 … 0.47 Inch | 10 … 12 mm / 0.39 … 0.47 Inch | 10 … 12 mm / 0.39 … 0.47 Inch | 10 … 12 mm / 0.39 … 0.47 Inch | 10 … 12 mm / 0.39 … 0.47 Inch |
| Total number of connection points | 2 | 2 | 2 | 3 | 3 | 3 | 4 | 4 | 4 |
| Total number of potentials | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| Type of mounting | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail |
| Type of wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring |
| Вес, г | 5.372 | 5.372 | 8.242 | 6.471 | 6.471 | 9.341 | 7.744 | 7.864 | 10.794 |
| Ширина | 5.2 mm / 0.205 inch | 5.2 mm / 0.205 inch | 5.2 mm / 0.205 inch | 5.2 mm / 0.205 inch | 5.2 mm / 0.205 inch | 5.2 mm / 0.205 inch | 5.2 mm / 0.205 inch | 5.2 mm / 0.205 inch | 5.2 mm / 0.205 inch |
Серия: 2202 (9)
