Datasheet Wago 285-181 — Даташит
2-проводная сквозная клеммная колодка; 95 мм²; боковые маркерные пазы; с фиксирующими фланцами; POWER CAGE CLAMP
Купить 285-181 на РадиоЛоцман.Цены — от 6 655 до 7 801 ₽2-CONDUCTOR THROUGH TERMINAL BLO | |||
| 285181-R | 6 655 ₽ | ||
| 285181-R | 7 801 ₽ | ||
| 2851.81.1524.201 Wago | по запросу | ||
| 285-181 Wago | по запросу | ||
| Цвет | gray |
| Connectable conductor materials | Copper |
| Connection technology | POWER CAGE CLAMP |
| Country of origin | PL |
| Габариты: глубина | 145 mm / 5.709 inch |
| Design | horizontal |
| Fine-stranded conductor | 25 … 95 mm² / 4 … 4/0 AWG |
| GTIN | 4055143583930 |
| Height from upper-edge of DIN-35 rail | 108 mm / 4.252 inch |
| Marking level | Side marking |
| Mounting type | Mounting flange |
| Number of levels | 1 |
| Rated current | 232 A |
| Rated impulse voltage (III / 3) | 8 kV |
| Rated voltage (III / 3) | 1000 В |
| Solid conductor | 25 … 95 mm² / 4 … 4/0 AWG |
| Strip length | 35 mm / 1.38 Inch |
| Total number of connection points | 2 |
| Total number of potentials | 1 |
| Type of wiring | Side-entry wiring |
| Вес | 270.429 г |
| Ширина | 25 mm / 0.984 inch |
Серия: 285 (83)
- 285-1161 285-1163 285-1164 285-1165 285-1167 285-1167/999-950 285-1169 285-1171 285-1175 285-1176 285-1177 285-1178 285-1179 285-1181 285-1184 285-1185 285-1187 285-131 285-132 285-134 285-135 285-136 285-137 285-137/999-950 285-139 285-141 285-144 285-147 285-148 285-150 285-151 285-154 285-157 285-157/999-950 285-159 285-168 285-169 285-170 285-172 285-175 285-181 285-184 285-187 285-188 285-191 285-194 285-195 285-197 285-197/999-950 285-199 285-327 285-337 285-338 285-400 285-401 285-407 285-415 285-416 285-420 285-421 285-427 285-430 285-435 285-440 285-441 285-447 285-448 285-449 285-450 285-495 285-601 285-604 285-607 285-607/999-950 285-634 285-635 285-637 285-637/999-950 285-691 285-935 285-950 285-992 285-995
