Datasheet Wago 285-1165 — Даташит
Серия285
Модель285-1165
Набор
Actuation typeOperating tool
Connection technologyPOWER CAGE CLAMP
Country of originQU
Габариты: глубина170 mm / 6.693 inch
Designhorizontal
Fine-stranded conductor50 … 185 mm² / 1/0 AWG … 350 kcmil
Fine-stranded conductor with ferrule with plastic collar50 … 150 mm² / 1/0 AWG … 300 kcmil
Fine-stranded conductor with ferrule without plastic collar50 … 185 mm² / 1/0 AWG … 350 kcmil
GTIN4055143657006
Height123 mm / 4.843 inch
Height from the surface123 mm / 4.843 inch
Marking levelSide marking
Mounting typeMounting flange
Nominal cross section185 mm²
Number of levels1
Rated impulse voltage (III / 3)12 kV
Rated impulse voltage (III / 3) 212 kV
Rated voltage (III / 3)1000 В
Rated voltage (III / 3) 21500 В
Solid conductor50 … 185 mm² / 1/0 AWG … 350 kcmil
Stranded conductor50 … 185 mm² / 1/0 AWG … 350 kcmil
Strip length45 … 47 mm / 1.77 … 1.85 Inch
Total number of connection points10
Total number of potentials4
Type of wiringSide-entry wiring
Вес2217.9 г
2851165, 285 1165
На английском языке: Datasheet Wago 285-1165
