Datasheet Wago 2006-8674 — Даташит
2-проводная клеммная колодка для отключения/тестирования; с возможностью тестирования; оранжевая разъединительная перемычка
| 2-CONDUCTOR DISCONNECT/TEST TERM | |||
| 2006-8674 Wago | по запросу | ||
| Actuation type | Open Tool Slot |
| Цвет | blue |
| Connectable conductor materials | Copper |
| Connection technology | Push-in CAGE CLAMP® |
| Country of origin | DE |
| Габариты: глубина | 106.9 mm / 4.209 inch |
| Design | horizontal |
| Fine-stranded conductor | 0.5 … 10 mm² / 20 … 8 AWG |
| Fine-stranded conductor with ferrule, push-in termination, from | 2.5 mm² / 16 AWG |
| Fire load | 0.673 MJ |
| GTIN | 4050821372516 |
| Height from upper-edge of DIN-35 rail | 33 mm / 1.299 inch |
| Marking level | Center/side marking |
| Nominal cross section | 6 mm² |
| Number of levels | 1 |
| Product Group | 22 (TOPJOB S) |
| Solid conductor | 0.5 … 10 mm² / 20 … 8 AWG |
| Solid conductor, push-in termination | 2.5 … 10 mm² / 14 … 8 AWG |
| Strip length | 13 … 15 mm / 0.51 … 0.59 Inch |
| Total number of connection points | 2 |
| Total number of potentials | 1 |
| Type of mounting | DIN-35 rail |
| Type of wiring | Front-entry wiring |
| Voltage type (1) | AC/DC |
| Вес | 31.425 г |
| Ширина | 15 mm / 0.591 inch |
Серия: 2006 (100 из 109)
- 2006-1294 2006-1301 2006-1302 2006-1304 2006-1307 2006-1391 2006-1392 2006-1393 2006-1394 2006-1601 2006-1604 2006-1611 2006-1611/1000-541 2006-1611/1000-542 2006-1611/1000-836 2006-1611/1000-867 2006-1621 2006-1621/1000-541 2006-1621/1000-542 2006-1621/1000-836 2006-1621/1000-859 2006-1631 2006-1631/099-000 2006-1631/1000-541 2006-1631/1000-542 2006-1631/1000-836 2006-1631/1000-859 2006-1631/1000-867 2006-1631/1099-541 2006-1631/1099-542 2006-1631/1099-836 2006-1631/1099-859 2006-1631/1099-867 2006-1661 2006-1664 2006-1671 2006-1671/1000-848 2006-1671/1000-849 2006-1671/1000-850 2006-1671/1000-851 2006-1674 2006-1681 2006-1681/1000-413 2006-1681/1000-414 2006-1681/1000-429 2006-1681/1000-434 2006-1681/1000-435 2006-1681/1000-449 2006-1691 2006-1692 2006-1695 2006-1696 2006-191 2006-401 2006-401/000-050 2006-402 2006-403 2006-404 2006-405 2006-405/011-000 2006-433 2006-434 2006-435 2006-451 2006-499 2006-511 2006-549 2006-7111 2006-7192 2006-7300 2006-8401 2006-8601 2006-8604 2006-8661 2006-8664 2006-8671 2006-8674 2006-8691 2006-8692 2006-911 2006-911/1000-541 2006-911/1000-542 2006-911/1000-836 2006-921 2006-921/1000-541 2006-921/1000-542 2006-921/1000-836 2006-921/1000-859 2006-931 2006-931/099-000 2006-931/1000-541 2006-931/1000-836 2006-931/1000-859 2006-931/1000-867 2006-931/1099-541 2006-931/1099-542 2006-931/1099-836 2006-931/1099-859 2006-991 2006-992
20068674, 2006 8674
