Datasheet Wago 2206 — Даташит
Серия2206
Datasheet Wago 2206
25 предложений от 10 поставщиков
Клеммная колодка на DIN рейку, Through, 2 вывод(-ов), 20 AWG, 8 AWG, 6 мм², Зажим, 41 А
2206-1201
от 325 ₽
452 ₽
2206-1201
от 477 ₽
Parameters / Models2206-1201
2206-1201
2206-1204
2206-1204
2206-1207
2206-1207
2206-1301
2206-1301
2206-1304
2206-1304
2206-1307
2206-1307
Actuation typePush-buttonPush-buttonPush-buttonPush-buttonPush-buttonPush-button
Цветgraybluegreen-yellowgraybluegreen-yellow
Connectable conductor materialsCopperCopperCopperCopperCopperCopper
Connection technologyPush-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®
Country of originDEDEDEDEDEDE
Габариты: глубина57.3 mm / 2.256 inch57.3 mm / 2.256 inch57.3 mm / 2.256 inch73.3 mm / 2.886 inch73.3 mm / 2.886 inch73.3 mm / 2.886 inch
Designhorizontalhorizontalhorizontalhorizontalhorizontalhorizontal
Fine-stranded conductor0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG
Fine-stranded conductor with ferrule, push-in termination, from1.5 mm² / 16 AWG1.5 mm² / 16 AWG1.5 mm² / 16 AWG1.5 mm² / 16 AWG1.5 mm² / 16 AWG1.5 mm² / 16 AWG
Fire load, MJ0.010.010.01
GTIN405514371202640551437120404055143712064405514371208840551437121014055143712125
Height from upper-edge of DIN-35 rail32.9 mm / 1.295 inch32.9 mm / 1.295 inch32.9 mm / 1.295 inch32.9 mm / 1.295 inch32.9 mm / 1.295 inch32.9 mm / 1.295 inch
Insulating materialPolyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)
Legend (ratings)(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3
Marking levelCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side marking
Nominal cross section6 mm²6 mm²6 mm²6 mm²6 mm²6 mm²
Number of levels111111
Packaging typeBOXBOXBOXBOXBOXBOX
Rated current, A41414141
Rated current (2), A57575757
Rated impulse voltage (III / 3), kV8888
Rated voltage (III / 3), В800800800800
Solid conductor0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG
Solid conductor, push-in termination1 … 10 mm² / 14 … 8 AWG1 … 10 mm² / 14 … 8 AWG1 … 10 mm² / 14 … 8 AWG1 … 10 mm² / 14 … 8 AWG1 … 10 mm² / 14 … 8 AWG1 … 10 mm² / 14 … 8 AWG
Strip length13 … 15 mm / 0.51 … 0.59 Inch13 … 15 mm / 0.51 … 0.59 Inch13 … 15 mm / 0.51 … 0.59 Inch13 … 15 mm / 0.51 … 0.59 Inch13 … 15 mm / 0.51 … 0.59 Inch13 … 15 mm / 0.51 … 0.59 Inch
Total number of connection points222333
Total number of potentials111111
Type of mountingDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 rail
Type of wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiring
Вес, г9.9679.96717.93812.93412.93420.905
Ширина7.5 mm / 0.295 inch7.5 mm / 0.295 inch7.5 mm / 0.295 inch7.5 mm / 0.295 inch7.5 mm / 0.295 inch7.5 mm / 0.295 inch
На английском языке: Datasheet Wago 2206
