Datasheet Wago 2022-2232 — Даташит
1-проводные / 1-контактные двухуровневые клеммы с розеткой; Проходные / проходные клеммы; N/L; с нанесением маркировки; для DIN-рейки 35 x 15 и 35 x 7,5; 2,5 мм²; Push-in CAGE CLAMP
1-CONDUCTOR/1-PIN DOUBLE DECK RE | |||
| 2022-2232 Wago | по запросу | ||
| Actuation type | Operating tool Push-in |
| Цвет | gray |
| Connectable conductor materials | Copper |
| Connection technology | Push-in CAGE CLAMP® |
| Country of origin | DE |
| Габариты: глубина | 80.1 mm / 3.154 inch |
| Design | horizontal |
| Fine-stranded conductor | 0.25 … 4 mm² / 22 … 12 AWG |
| Fine-stranded conductor with ferrule, push-in termination, from | 0.75 mm² / 18 AWG |
| Fire load | 0.259 MJ |
| GTIN | 4045454916565 |
| Height from upper-edge of DIN-35 rail | 61.4 mm / 2.417 inch |
| Marking level | Side marking |
| Nominal cross section | 2.5 mm² |
| Number of levels | 2 |
| Potential marking | L/L |
| Product Group | 18 (X-COM-System) |
| Rated current | 24 A |
| Rated current (2) | 28 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (III / 3) | 690 В |
| Solid conductor | 0.25 … 4 mm² / 22 … 12 AWG |
| Solid conductor, push-in termination | 0.75 … 4 mm² / 18 … 12 AWG |
| Strip length | 10 … 12 mm / 0.39 … 0.47 Inch |
| Total number of connection points | 2 |
| Total number of potentials | 2 |
| Type of mounting | DIN-35 rail |
| Type of wiring | Front-entry wiring |
| Вес | 12.199 г |
| Ширина | 5.2 mm / 0.205 inch |
Серия: 2022 (100 из 251)
- 2022-114 2022-114/000-006 2022-114/000-012 2022-114/000-016 2022-114/000-037 2022-114/000-039 2022-114/126-000 2022-114/136-000 2022-114/146-000 2022-115 2022-115/000-006 2022-115/000-012 2022-115/000-016 2022-115/000-037 2022-115/000-039 2022-115/127-000 2022-115/137-000 2022-115/147-000 2022-1201 2022-1201/999-953 2022-1202 2022-1204 2022-1204/999-953 2022-1207 2022-1207/999-953 2022-1291 2022-1292 2022-1301 2022-1301/999-953 2022-1302 2022-1304 2022-1304/999-953 2022-1307 2022-1307/999-953 2022-1391 2022-1392 2022-1401 2022-1401/999-953 2022-1402 2022-1404 2022-1404/999-953 2022-1407 2022-1407/999-953 2022-141 2022-142 2022-1491 2022-1492 2022-151 2022-152 2022-161 2022-162 2022-164 2022-167 2022-171 2022-172 2022-174 2022-177 2022-181 2022-182 2022-184 2022-187 2022-2201 2022-2201/999-953 2022-2202 2022-2202/999-953 2022-2203 2022-2203/999-953 2022-2204 2022-2204/999-953 2022-2207 2022-2207/999-953 2022-2208 2022-2208/999-953 2022-2209 2022-2209/999-953 2022-2217 2022-2217/999-953 2022-2227 2022-2227/999-953 2022-2231 2022-2231/999-953 2022-2232 2022-2232/999-953 2022-2233 2022-2233/999-953 2022-2234 2022-2234/999-953 2022-2237 2022-2237/427-000 2022-2237/999-953 2022-2238 2022-2238/999-953 2022-2239 2022-2239/999-953 2022-2247 2022-2247/999-953 2022-2257 2022-2257/999-953 2022-2291 2022-2292
- Rail / Chassis Terminal blocks | Pluggable Connection Systems
20222232, 2022 2232
