Datasheet Wago 2216 — Даташит
| Производитель | Wago |
| Серия | 2216 |
Купить 2216-1201 на РадиоЛоцман.Цены — от 480 до 746 ₽17 предложений от 6 поставщиков Клеммная колодка на DIN рейку, 2 вывод(-ов), 20 AWG, 6 AWG, 16 мм², Вставной, 76 А | |||
| 2216-1201 Wago | от 480 ₽ | ||
| 2216-1201 Wago | 659 ₽ | ||
| 2216-1201 Wago | по запросу | ||
| 2216-1201 Wago Оф. дистрибьютор | по запросу | ||
| Parameters / Models | 2216-1201![]() | 2216-1204![]() | 2216-1207![]() | 2216-1301![]() | 2216-1304![]() | 2216-1307![]() |
| Actuation type | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button |
| Цвет | gray | blue | green-yellow | gray | blue | green-yellow |
| Connectable conductor materials | Copper | Copper | Copper | Copper | Copper | Copper |
| Connection technology | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® |
| Country of origin | DE | DE | DE | DE | DE | DE |
| Габариты: глубина | 69.8 mm / 2.748 inch | 69.8 mm / 2.748 inch | 69.8 mm / 2.748 inch | 91.8 mm / 3.622 inch | 91.8 mm / 3.622 inch | 91.8 mm / 3.622 inch |
| Design | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal |
| Fine-stranded conductor | 0.5 … 25 mm² / 20 … 4 AWG | 0.5 … 25 mm² / 20 … 4 AWG | 0.5 … 25 mm² / 20 … 4 AWG | 0.5 … 25 mm² / 20 … 4 AWG | 0.5 … 25 mm² / 20 … 4 AWG | 0.5 … 25 mm² / 20 … 4 AWG |
| Fine-stranded conductor with ferrule, push-in termination, from | 2.5 mm² / 14 AWG | 2.5 mm² / 14 AWG | 2.5 mm² / 14 AWG | 2.5 mm² / 14 AWG | 2.5 mm² / 14 AWG | 2.5 mm² / 14 AWG |
| GTIN | 4055143732727 | 4055143732734 | 4055143732765 | 4055143732789 | 4055143732796 | 4055143732802 |
| Height from upper-edge of DIN-35 rail | 37.1 mm / 1.461 inch | 37.1 mm / 1.461 inch | 37.1 mm / 1.461 inch | 37.1 mm / 1.461 inch | 37.1 mm / 1.461 inch | 37.1 mm / 1.461 inch |
| Insulating material | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) |
| Legend (ratings) | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | ||
| Marking level | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking |
| Nominal cross section | 16 mm² | 16 mm² | 16 mm² | 16 mm² | 16 mm² | 16 mm² |
| Number of levels | 1 | 1 | 1 | 1 | 1 | 1 |
| Packaging type | BOX | BOX | BOX | BOX | BOX | BOX |
| Rated current, A | 76 | 76 | 76 | 76 | ||
| Rated current (2), A | 90 | 90 | 90 | 90 | ||
| Rated impulse voltage (III / 3), kV | 8 | 8 | 8 | 8 | ||
| Rated voltage (III / 3), В | 800 | 800 | 800 | 800 | ||
| Solid conductor | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG |
| Solid conductor, push-in termination | 2.5 … 16 mm² / 14 … 6 AWG | 2.5 … 16 mm² / 14 … 6 AWG | 2.5 … 16 mm² / 14 … 6 AWG | 2.5 … 16 mm² / 14 … 6 AWG | 2.5 … 16 mm² / 14 … 6 AWG | 2.5 … 16 mm² / 14 … 6 AWG |
| Strip length | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch |
| Total number of connection points | 2 | 2 | 2 | 3 | 3 | 3 |
| Total number of potentials | 1 | 1 | 1 | 1 | 1 | 1 |
| Type of mounting | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail |
| Type of wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring |
| Вес, г | 23.78 | 23.78 | 39.732 | 32.229 | 32.229 | 48.002 |
| Ширина | 12 mm / 0.472 inch | 12 mm / 0.472 inch | 12 mm / 0.472 inch | 12 mm / 0.472 inch | 12 mm / 0.472 inch | 12 mm / 0.472 inch |
