Datasheet Wago 784-992 — Даташит
2-проводная проходная клеммная колодка; 10 мм²; подходит для применений Ex e II; маркировка центра; для DIN-рейки 35 x 15 и 35 x 7,5; CAGE CLAMP
2-CONDUCTOR THROUGH TERMINAL BLO | |||
| 784-992 Wago | по запросу | ||
| Цвет | light gray |
| Connectable conductor materials | Copper |
| Country of origin | DE |
| Габариты: глубина | 82.5 mm / 3.248 inch |
| Design | angled |
| Fine-stranded conductor | 0.2 … 10 mm² / 24 … 8 AWG |
| Fine-stranded conductor (2) | 0.2 … 16 mm² / 24 … 6 AWG |
| Fire load | 0.339 MJ |
| GTIN | 4044918806022 |
| Height from upper-edge of DIN-35 rail | 43.5 mm / 1.713 inch |
| Marking level | Center marking |
| Number of levels | 1 |
| Rated voltage EN (Ex e II) | 750 В |
| Solid conductor | 0.2 … 10 mm² / 24 … 8 AWG |
| Solid conductor (2) | 0.2 … 16 mm² / 24 … 6 AWG |
| Strip length | 12 … 13 mm / 0.47 … 0.51 Inch |
| Total number of connection points | 2 |
| Total number of potentials | 1 |
| Type of mounting | DIN-35 rail |
| Type of wiring | Front-entry wiring |
| Вес | 22.9 г |
| Ширина | 10 mm / 0.394 inch |
