Datasheet Wago 727-128/002-000 — Даташит
8-уровневая клеммная колодка с одинаковым потенциалом
| 727-128/002-000 Wago | по запросу | ||
| Цвет | light gray |
| Connectable conductor materials | Copper |
| Country of origin | DE |
| Габариты: глубина | 226 mm / 8.898 inch |
| Design | horizontal |
| Fine-stranded conductor | 0.08 … 1.5 mm² / 28 … 16 AWG |
| Fire load | 1.187 MJ |
| GTIN | 4045454187651 |
| Height from upper-edge of DIN-35 rail | 58.5 mm / 2.303 inch |
| Marking | a-b-c-d-e-f-g-h--h-g-f-e-d-c-b-a |
| Marking level | Center marking |
| Number of levels | 8 |
| Rated current | 18 A |
| Rated voltage (III / 3) | 250 В |
| Solid conductor | 0.08 … 1.5 mm² / 28 … 16 AWG |
| Strip length | 8 … 10 mm / 0.31 … 0.39 Inch |
| Total number of connection points | 32 |
| Total number of potentials | 1 |
| Type of mounting | DIN-35 rail |
| Type of wiring | Front-entry wiring |
| Вес | 61.725 г |
| Ширина | 7.62 mm / 0.3 inch |
Серия: 727 (100 из 238)
- 727-115 727-116 727-117 727-119 727-119/001-000 727-119/002-000 727-119/003-000 727-119/004-000 727-120 727-120/001-000 727-120/002-000 727-120/003-000 727-120/004-000 727-121 727-121/001-000 727-121/002-000 727-121/003-000 727-121/004-000 727-122 727-122/001-000 727-122/002-000 727-122/003-000 727-122/004-000 727-123 727-123/001-000 727-123/002-000 727-123/003-000 727-123/004-000 727-124 727-124/001-000 727-124/002-000 727-124/003-000 727-124/004-000 727-125 727-125/001-000 727-125/002-000 727-125/003-000 727-125/004-000 727-126 727-126/001-000 727-126/002-000 727-126/003-000 727-126/004-000 727-127 727-127/001-000 727-127/002-000 727-127/003-000 727-127/004-000 727-128 727-128/001-000 727-128/002-000 727-128/003-000 727-128/004-000 727-129 727-129/001-000 727-129/002-000 727-129/003-000 727-129/004-000 727-130 727-130/001-000 727-130/002-000 727-130/003-000 727-130/004-000 727-131 727-131/001-000 727-131/002-000 727-131/003-000 727-131/004-000 727-132 727-132/001-000 727-132/002-000 727-132/003-000 727-132/004-000 727-133 727-133/001-000 727-133/002-000 727-133/003-000 727-133/004-000 727-134 727-134/001-000 727-134/002-000 727-134/003-000 727-134/004-000 727-135 727-135/001-000 727-135/002-000 727-135/003-000 727-135/004-000 727-136 727-136/001-000 727-136/002-000 727-136/003-000 727-136/004-000 727-137 727-137/001-000 727-137/002-000 727-137/003-000 727-137/004-000 727-138 727-138/001-000
727128/002000, 727 128/002 000
