Datasheet Wago 294-8325 — Даташит
Разъем питания; версия 17 мм; с угловым защелкивающимся заземляющим контактом; L´-N´-L-PE-N; 5-полюсный
| Actuation type | Push-button |
| Actuation type 2 | Push-in |
| Actuation type 3 | Push-in |
| Actuation type 4 | Push-in |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | white |
| Connection technology | Push-in CAGE CLAMP® |
| Connection technology 2 | PUSH WIRE® |
| Connection technology 3 | PUSH WIRE® |
| Connection technology 4 | PUSH WIRE® |
| Connection type (1) | External 1 |
| Connection type (2) | Internal 2 |
| Connection type (3) | Internal 3 |
| Connection type (4) | Internal 4 |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | PL |
| Габариты: глубина | 27.3 mm / 1.075 inch |
| Fine-stranded conductor | 0.5 … 2.5 mm² / 18 … 14 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.5 … 1.5 mm² / 18 … 16 AWG |
| Fine-stranded conductor with ferrule without plastic collar | 0.5 … 1.5 mm² / 18 … 16 AWG |
| Fine-stranded conductor with ferrule, push-in termination, from | 0.5 mm² / 18 AWG |
| Fine-stranded conductor with insulated ferrule (2) | 0.5 … 1 mm² / 18 … 14 AWG |
| Fine-stranded conductor with insulated ferrule (3) | 0.5 … 0.75 mm² / 18 AWG |
| Fine-stranded conductor with uninsulated ferrule (2) | 0.5 … 1.5 mm² / 18 … 16 AWG |
| Fine-stranded conductor with uninsulated ferrule (3) | 0.5 … 1 mm² / 18 … 14 AWG |
| Fire load | 0.332 MJ |
| GTIN | 4050821098904 |
| Ground function | with angled snap-in GND contact |
| Height | 22.4 mm / 0.882 inch |
| Height from the surface | 17 mm / 0.669 inch |
| Insulating material | Polycarbonate (PC) |
| Marking | L' N' L ⏚ N |
| Material group | III a |
| Number of Poles | 5 |
| Number of connection points | 1 |
| Number of connection points (connection type) | 2 |
| Number of connection types | 4 |
| Packaging type | bag |
| Product Group | 8 (Misc. Chassis Mount Blocks) |
| Rated current | 24 A |
| Rated current (2) | 24 A |
| Rated current (3) | 16 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (II / 2) 2 | 4 kV |
| Rated impulse voltage (II / 2) 3 | 4 kV |
| Rated voltage (II / 2) | 500 В |
| Rated voltage (II / 2) 2 | 500 В |
| Rated voltage (II / 2) 3 | 500 В |
| Ratings Note 3 | Linect® plug-in connection |
| Ratings according to 2 | IEC/EN 60998-2-2 |
| Ratings according to 3 | IEC/EN 61984 |
| Ratings note | Connection points |
| Ratings note 2 | Connection points |
| Solid conductor | 0.5 … 2.5 mm² / 18 … 12 AWG |
| Solid conductor (2) | 0.5 … 2.5 mm² / 18 … 14 AWG |
| Solid conductor (3) | 0.5 … 1.5 mm² / 18 … 16 AWG |
| Solid conductor (4) | 0.5 … 0.75 mm² / 18 AWG |
| Solid conductor, push-in termination | 0.5 … 2.5 mm² / 18 … 12 AWG |
| Stranded conductor | 0.5 … 2.5 mm² / 18 … 14 AWG |
| Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
| Strip length (2) | 8 … 9 mm / 0.31 … 0.35 Inch |
| Strip length (3) | 8 … 9 mm / 0.31 … 0.35 Inch |
| Strip length (4) | 8 … 9 mm / 0.31 … 0.35 Inch |
| Temperature stability | 120 °C |
| Total number of potentials | 5 |
| Вес | 17.11 г |
| Ширина | 50 mm / 1.969 inch |
Серия: 294 (100 из 151)
- 294-4355 294-4375 294-4413 294-4414 294-4415 294-4423 294-4424 294-4425 294-4435 294-4453 294-4455 294-4475 294-5002 294-5003 294-5004 294-5005 294-5012 294-5013 294-5014 294-5015 294-5022 294-5023 294-5024 294-5025 294-5032 294-5035 294-5042 294-5043 294-5044 294-5045 294-5052 294-5053 294-5055 294-5072 294-5075 294-5094/4025-000 294-5113 294-5114 294-5123 294-5124 294-5153 294-5155 294-5175 294-5213 294-5214 294-5215 294-5223 294-5224 294-5225 294-5235 294-5253 294-5255 294-5275 294-5313 294-5314 294-5315 294-5323 294-5324 294-5325 294-5335 294-5353 294-5355 294-5375 294-5413 294-5414 294-5415 294-5423 294-5424 294-5425 294-5435 294-5453 294-5455 294-5475 294-8013 294-8015 294-8022 294-8024 294-8025 294-8032 294-8035 294-8113 294-8115 294-8124 294-8125 294-8135 294-8213 294-8215 294-8224 294-8225 294-8235 294-8313 294-8315 294-8324 294-8325 294-8335 294-8413 294-8415 294-8424 294-8425 294-8435
2948325, 294 8325
